LTPWS issue
Old Apr 27, 2011 | 03:21 PM
JerryCVA-61's Avatar
JerryCVA-61
Default LTPWS issue
[/B] Is there any way to remove the bulb from the driver info. center on my 1995? The ltpws light comes on shortly after driving a few miles....the tire pressure is fine......I check it regularly.
Old Apr 27, 2011 | 08:14 PM
Red Dwarf's Avatar
Red Dwarf
The LTPWS will tell you if you have a low tire....Low tire. Otherwise will indicate service LTPWS.
You probably have a bad sensor or receiver.
There shud be some info in the "search" section relative to removing the bulb (s).
Old Apr 28, 2011 | 12:10 AM
Dads90's Avatar
Dads90
Remove the bolts holding the drink holder down, pull that up and it exposes the lower bolts of the radio bezel, remove those, bolts are located around the outer edges. Also the AC vent has two screws holding it in. Pull the bezel away gently cause it snaps in a couple of places. The DIC is held in by screws, once they are removed the DIC just unplugs. The bulbs just untwist from the back. OR just put electric tape over the cell the bulb is housed in and once you put the DIC film cover back on you can't see it. That way you don't misplace the bulb. Either way works.
To LTPWS issue
