bushings......
Old Apr 19, 2002 | 09:42 AM
scorpion's Avatar
scorpion
Default bushings......
i have to replace the bushings on my 95, and i found out, only available with the control arm! so i'm thinking aboout polyurethane or poly graphite
any suggestions????
please advise
b.
Old Apr 19, 2002 | 10:09 AM
fiddleplayer's Avatar
fiddleplayer
Default Re: bushings...... (scorpion)
I replaced all the bushings on my 86 with the poly graphite. It tightened up the car real well. I used performance suspension.
http://www.performancesuspension.com/
Old Apr 19, 2002 | 10:45 AM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
Default Re: bushings...... (fiddleplayer)
I Replaced my bushing last week to heim. Feel very solid !
Here are a few pic's
Old Apr 19, 2002 | 12:27 PM
damionvoss's Avatar
damionvoss
Default Re: bushings...... (Coupe89)
I've been planning on doing my bushings for a while now. How difficult of a job is it? Any special tools required? How long did it take you guys to do? Thanks!
Old Apr 19, 2002 | 12:41 PM
fiddleplayer
Default Re: bushings...... (damionvoss)
I did the rear bushings, u-joints, bearings, shocks, and brake pads, in one day. The front bushings, shocks, upper and lower ball joints, tie rod ends, and brake pads in two evenings , one evening per side.
I put the car up on 4 jack stands.
The front passenger side upper is the hardest. The Idler pulley must be removed and the air conditioner canister un mounted so you can mover the a/c hoses out of the way. you do not need to disconnect the a/c hoses.
I have an arbor press, a ball joint/ u-joint press, and a tie rod end seperator. You will also need several metric wrenches/sockets larger than 18mm
Since mine is an 86, the upper ball joint rivets had gaulded to the aluminum upper control arms so I had to drill them out. Most of the time you can just grind off the heads of the rivets and press them out.
[Modified by fiddleplayer, 10:42 AM 4/19/2002]
Old Apr 19, 2002 | 01:37 PM
scorpion's Avatar
scorpion
how about a spring compressor? is one needed, or can you release the tension of the spring safely?
Old Apr 19, 2002 | 09:13 PM
Bluevette85's Avatar
Bluevette85
fiddleplayer is right on with the process. You don't need a spring remover. A floor jack can be used to decompress the rear spring. I got a shock when the rear spring bolts were removed. They has started to corrode just above the threads so they were replaced. On my car, the back bushings were very worn and loose. The front bushings could have been left alone but the lower ball joints were worn. PST sells a complete kit and the price can't be beat. www.p-s-t.com
Old Apr 19, 2002 | 10:18 PM
fiddleplayer
Default Re: bushings...... (Bluevette85)
I double checked when I got home and I used P-S-T on the front also. I bought the whole kit for the front. Everything fit well. You should go ahead and do the swaybars at the same time. They will have to know the diameter of both the front and the rear. The sway bar bushings are sold seperately. I had a little trouble with the ends of the sway bars though.
Old Apr 22, 2002 | 03:03 PM
scorpion's Avatar
scorpion
THANK YOU, guys!
you were a very big help for my decision, and i will go ahead and buy that stuff now. again thank you for all your input!
it is great to be part of a family which is so helpful like this forum!
b
Old Apr 22, 2002 | 03:19 PM
Wheelman's Avatar
Wheelman
can this be done without a ball joint press and an arbor press........i am not familiar with these tools...if not are the expensive and where can i get them. Also, do you need to align your car after you do this?
thanks
Old Apr 22, 2002 | 03:21 PM
89'Bowtie's Avatar
89'Bowtie
St. Jude Donor '13
How much was that upgrade..looks very nice.
Victor
Old Apr 22, 2002 | 03:27 PM
scorpion's Avatar
scorpion
Default Re: bushings...... (89'Bowtie)
an alignment is highly recomended, since you had everything apart, and with the new bushings you are for sure off the old alignment.
Old Apr 22, 2002 | 03:29 PM
scorpion's Avatar
scorpion
Default Re: bushings...... (C4Fetish)
you will need some heavy tools, like the press, but i'm sure ther is an alternative method :), if you are careful.
i would say you do not need the ball joint press, but the seperator for sure helps a lot
[Modified by scorpion, 2:30 PM 4/22/2002]
Old Apr 22, 2002 | 03:49 PM
fiddleplayer
I bought them all from harbor freight. It's not professional quality but it got the job done. The arbor press, balljoint press, and the tie rod seperator were all together around $100. Too bad you're not in Dallas, you could use mine. Having the right tools makes the job go easier and faster.
Old Apr 22, 2002 | 08:35 PM
6spd89's Avatar
6spd89
Cruise-In II Veteran
Check the tech tips on how i did my front bushings!
I am still doing the rears and polishing the control arms as i go.
Matt
To bushings......
