My new 383 with about 500 miles on the motor started making a slight knocking sound under the front of the motor. I don't get it until the motor is warm and is only noticable at idle. Are stroked motors with forged pistons known for any piston slap? I have plenty of rod and piston clearance on the block. Also it only seams to be coming from the very front and also seems to be coming from the bottom of the motor. Any thoughts? I just got this thing running good to, this is realy got me worried
Not that I've ever heard about...typically thats why we have forged pistons, to withstand some abuse that the cast aluminum will not.
Mine also has a noise thats not a knock, more like a rubbing or bumping that comes and goes...in the bottom, except toward the rear. Can;t hear it under the hood, mostly in the cabin at idle. Gone the next day, and cannot pin it down.
My thoughts are crank run-out. I can;t prove it without pulling it apart, but thats the only thing that makes any sense...the crank floating back & forth in the bearings and main seals . Its so mild and intermittent that its hard to justify deeper examination.
Is this possible with your new build? Crank run-out gets overlooked sometimes.
Piston slap usually happends when the motor is cold and the piston to cylinder wall clearance is at it's greatest. Knocking when warm can be bearing noise when oil viscosity decreases. Stroker motors shouldn't be any noisier than standard stroke motors unless the block wasn't clearanced and the rods are contacting the block or if there is an internal mechanical problem.
If you installed the double roller, did you installed the new water pump gear set?
Yes I have a double row that had lots of clearance issues but I couldn't feel any issues when turning it over by hand after I and cleaned up the bad spots. I have a 92 block with upgraded distributor and an electric water pump. If it was a bad bearing wouldn't it do it all the time i.e. when cold?
Ok I just did the old wooden dowl rod as a listening device and it's definately coming from the bottom of the chain case cover and within. I hope it's only a timming chain clearance issue, the only problem is I would think if the chain was hitting it would be a more continues noise wouldn't it? This noise has the timming of the crank revolution "if that makes sense".
If bearing clearances were good on install what would be causing this? I have great oil pressure but I noticed at idle there doesn't seem to be any oil laying in the heads or valve covers until the rpm's are brought up?
Would the metal in the filter have a certain look compared to metal from the timming chain rubbing or somthing?
Reason: add
Cut open you oil filter to see what's in there. If it's a bearing knock, you'll know quickly.
Ok I changed the oil and opened the old filter. What is the telltale sign of a bearing failure? I don't see anything gleaming, there are some small slivers that seem almost like aluminum other than they are whitish in colore and don't seem magnetic either, could this be a coating on the bearing?
my left catalytic converter brick fell apart when I high centered, The brick pieces are in the muffler, and it sounds like a diesel. Only inside. outside, it sounds like a little guy with a precisely timed hammer.
BTW, the right brick bounced around enough that it was like sand. The cat housing was empty. nothing but the air pipe.
I just had bullet cats put on it Wed.
and it's a 383 that sounds like there's noise coming from just under the plenum.
Been there since I first fired it up on the run stand, and I took the entire intake off, and checked everything out, but couldn't find anything.
