L98 help needed
Still having some minor problems though hopefully you guys will have some more advise for me.
#1 is well, the fans aren't coming on this is a problem that exsted before i parked it but i forgot until just now
i know they work because they come on randomly sometimes but they wont come on when you need them... i assume its just a relay/wiring issue issue.#2 its idleing a bit high...and its compounded with speed. i tried like hell to find a vac leak but from the looks of it there isn't one... also at low rpm (800-1800 or so) it breaks up quite a bit and sometimes i still need to have the gas to the floor to start it...
thanks again everyone
I plan to add a full bottle of seafoam next tank
If there is water in the tank I have had that on customer's cars, siphoned it all out, refilled but had wierd intermittant engine problems afterwards (stumbling, etc). I learned that I had to drop the tank and would find small globules of water running around in it. Flushing the tank and the fuel lines all the way up to the engine was the only sure way I was able to solve those problems. It stunk but I always had to drop the tank.
i see what you're saying and i hope this isn't my case but if it is so be it...i don't feel bad for myself after letting this go so long.
can anyone help my on the fan issue? as this is the most prevalent problem keeping me from driving the car at the moment.. thanks
There's more than 1 style of relay. The later ones (88 & up??) had a more sealed electrical connection.
any clue on thats location?
thanks man
If you jumper Pin E (red) to Pin A (black/red) at the relay connector, the fan should run. This will check the fusible links, the fan motors, and the G117 ground.
The ECM provides the ground for the norman relay operation based on inputs from the temp sensor, speed sensor and for the secondary, a/c operation. Does your secondary fan come on when you turn on the a/c?
The coolant temp sensor is below the u shaped rubber coolant line right below the throttle body. Check the connector and replace the sensor as needed.
Also, check your ECM "green" and "gray" connectors for good contact of the pins in the sockets or corrosion. The ECM reference voltages and ground signals all run through there.
#2 - You may have some leaking injectors, erratic TPS voltages, or a sticking IAC. Clean your IAC, Check your TPS voltages for .54 at idle, smoothly advancing to 4.5+ volts at WOT. The ECM voltage data for the TPS is also fed throught the ECM "green connector". Finally, check for fuel pressure decay at the rail.
it also improved the cars idle/running 95% it's not 100% and still has a hickup here and there but she's running very well. Thanks for all the help again. I'm gonna put another 500miles on it and so and if she doesn't completely come around I'll replace the injectors
Whenever i make a VERY hard left turn (possibly right as well but if so not as pronounced) it stutters and kicks as if the fuel as turned off with the flick of a switch... straight line absolutely no problem and the turn has to be HARD like tire screeching hard.
anyone have any idea? ProjectC4, is that similar to what you were talking about?
Try it with a full tank just to make sure its not sucking air. Maybe if you make enough hard left turns you'll suck up all the water eventually. Put some dry gas in there too so at least it's a water/alcohol mix.
As a practice, I would have the injectors cleeaned and tested ever few years. Seafoam and all those "cleaner in a can" stuff is like sweeping a large room in the dark. You have a pile of dirt but you won't really know how much you cleaned and how much is left.
