power door locks
Old May 2, 2011 | 01:29 PM
tdauphin's Avatar
tdauphin
4th Gear
Default power door locks
I have a 94 coupe,and the door locks when you walk up to it don't unlock.It trys to unlock by a little movement,and interior light doesn't come on.They will open when using the power door lock button inside though.The remote is programmed because hatch window will open with that.Anyone have this problem?Thanks
Old May 2, 2011 | 07:40 PM
bac22's Avatar
bac22
I suspect a bad PKE module. I'm having a similar problem on my 96.
Old May 3, 2011 | 11:06 AM
Stevenix1's Avatar
Stevenix1
Cruising
The hatch button doesn't have anything to do with the PKE function. It just shows you have signal output from the remote.
When you first insert the ignition key, and turn on the ignition (you don't have to start the car), in the lower left corner of the DIC it should show the PKE light for 2 seconds. If it doesn't show the PKE warning light, you have to turn the PKE function on by closing the doors and standing outside the car and holding down the DOOR button until the locks actually cycle by locking and then unlocking.
Then, your PKE light will light on ignition, and the PKE will work.
Old May 3, 2011 | 12:39 PM
tdauphin's Avatar
tdauphin
4th Gear
Default locks
Thank you I'll try it
Old May 3, 2011 | 03:36 PM
markKlein's Avatar
markKlein
What exactly are you saying? Are you saying the doors lock when you walk away from it? But won't unlock when you walk back to it? Or are you saying you can lock the doors from the inside and expect the doors to unlock when you walk back to it? I really can't tell from your description. Do what Steven suggested, the doors should lock when you walk away, and unlock when you walk back to the car.
Old May 3, 2011 | 07:41 PM
TWISTERUP's Avatar
TWISTERUP
Does the passenger door unlock when you push the button on the remote ?
Old May 4, 2011 | 05:25 PM
tdauphin's Avatar
tdauphin
4th Gear
Default pke
Thanks for the help.The pke was turned off
Old May 4, 2011 | 05:27 PM
tdauphin's Avatar
tdauphin
4th Gear
I did what you said and it worked.It turned the pke on
Old May 4, 2011 | 09:42 PM
SteveNix's Avatar
SteveNix
That's great! Glad to help! Thanks for getting back and letting us know.
To power door locks
