Need help bad...
Old May 3, 2011 | 12:23 PM
hifivinmofo's Avatar
hifivinmofo
Default Need help bad...
So here is the deal. I have a 1995 base coupe with 116,xxx miles automatic trans. Last year I replaced the entire ignition system with MSD Pro billet distributor, cap, rotor, wires, coil, new plugs, new water pump, the works right... Well now I am having an issue with it running rich but throwing a lean bank code?!?!?!? I have already replaced all of the o2 sensors, which made it go away for a while. Now the issue has returned. I have already gone through and tightened up the pcv system and checked for vac leaks. I have pulled the valve covers and checked all of that out as well... I am at a loss for a solution to this issue and am now thinking of selling the car due to the issue. Anyone who may have seen this issue or dealt with it in any way before your input would be greatly appreciated.
Old May 3, 2011 | 02:55 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
I would suspect a fuel injector problem. I'd start by checking them with an ohm meter.
Old May 3, 2011 | 06:12 PM
Kmcoldcars's Avatar
Kmcoldcars
My 1992 would give me intermittent code 44 - left bank oxygen sensor lean. I poured 2 bottles of Techron in the tank and drove it. The code seems to have gone away and the car even idles a lot smoother now.
Old May 3, 2011 | 07:27 PM
TWISTERUP's Avatar
TWISTERUP
Have you checked fuel pressure ? Could be a bad FPR leaking fuel to the vacuum side. If as you suspect it is running rich the O2 sensor would be steady/stuck at .9 to 1.0 volts-- the PCM would respond to the O2 via fuel trim (dialing back the "on" time of the injectors) if the PCM has adjusted as much as it can to lean out the fuel system and the o2 is still "stuck" in the 1.0 volt range--the PCM will set a "stuck lean" code. In closed loop on a correctly working system the O2 voltage should vary constantly back and forth between .1 and .9 volts. If you have access to a scan tool (not a paper clip or a code reader) you can see your self on the data list what the PCM sees from the O2s--MAF--CTS etc. May be a sensor out of range,but I'd check fuel pressure first.
BTW If I didn't make myself clear the "stuck lean" code does not mean the engine is actually running lean--it means the PCM has done everything it can to make it "leaner" and is unable system still too rich.
Old May 4, 2011 | 10:17 AM
hifivinmofo
Yeah I have a snap-on scan tool that has OBD1.5 interface on it. The o2's are functioning properly as the milivolts are right. It is actually going into "safe mode" (open loop) after the heater cycle is already complete and the o2's are up to normal operating temperature. as it does this it feels as if it is drastically pulling the timing out and causing it to misfire. Will check the FPR and Injectors. By the way I am a serious gearhed with a nice garage... I understood well what you meant by the way. Thank you for all of the input. Keep it coming though as this may or may not be the issue.
Old May 4, 2011 | 10:18 AM
hifivinmofo
I am in So-Cal right now and will be through the twenty fourth of this month... I will have to check it when I get back to Texas.
Old May 4, 2011 | 10:46 AM
leesvet's Avatar
leesvet
I'd do the leak-down on the injectors...pressure needs to be stable at around 40. Should hold 90% of that for an hour...should not drop to 20 for several hrs.
If it does, then start pulling plugs looking for a dirty one.
This could also come from low or inconsistant FP...plugged filter or sock.
Low voltage in the ign will make it spit and misfire. The stock ign was probably more than enough when its maintained. These aftermarket ign cause more trouble than they are worth on a semi-stock engine.Its the "placebo" effect that sells those things. Guys spend a few hundred and the car will run better....after doing that, you can't walk around saying it does not..
Vacuum leak...EGR stuck open. Easy to test with a stick-mirror and vac.
You should see an o2 sensor going out of normal range if there is a major issue with an inj thats dumping too much fuel. That would have to be drastic to send it to open loop via the o2 sensor, I'd think..
I'd be more inclined to look at air problems...leaks and other means of unmetered air entering combustion.
To Need help bad...
