Speedometer problem
Old May 3, 2011 | 04:30 PM
Rbuet's Avatar
Rbuet
Default Speedometer problem
About a year ago, I had 4.11 gears installed in my 95 M6, and I got a new mail order tune for the car.
Since then, the speedometer display shows 0, 1, 2 or 3, depending on my actual speed (3=approx. 60 mph).
When I log via TTS Datamaster, the log shows the same values (0,1,2,3) in the Mph value.
Using TunerPro RT, I see the "Speedometer Scalar" parameter = 2.00 and the "Speedometer Scalar, Fractional" is set at .59.
Does this mean my PCM thinks I have 2.59 gears and thus the problem with my speedometer values?
Also, the odometer also reads very low. It recorded approx. 0.6 miles on a 10 mile drive.
By the way, I have already replaced the VSS.
Any ideas?
Ron
Old May 5, 2011 | 01:44 PM
Rbuet's Avatar
Rbuet
Default Any ideas?
Anyone with any ideas on where to start in resolving this problem?
Old May 5, 2011 | 02:47 PM
engle1147's Avatar
engle1147
Usually - if the VSS has any output voltage what-so-ever the VSS isn't the issue. Your old/used VSS is more than likely in working order. Question: with the the old/used VSS installed did the speedo read 1,2,3 or was it reading "higher" before the "swap".....if so it may be your have a partial problem with the new VSS sensor or the installation.
Quite a few 90-96 clusters can have problems over time...failing speedo/tach is pretty common issue. So the cluster could be part of the problem.
I'm pretty sure you can't "tune"/calibrate speedo values for your year 'vette I believe you have to change the speedo gears on the transmissions output shaft to get the correct value at the ECM - you may want to ask about this in the scan & tune section though.
If your VSS at the ecm/pcm is in fact way off or non existant your car may "run" like crap.
Old May 5, 2011 | 05:42 PM
STL94LT1's Avatar
STL94LT1
The speedo can be recalibrated thru the PCM on the 94-96 LTx cars.
Give me a day or two and I'll look up the correct values.
Old May 6, 2011 | 01:23 PM
Rbuet's Avatar
Rbuet
Default From the OP:
I replaced the VSS because I thought it was the cause of the low reading. The replacement had no impact.
Thank you both for your help!
Ron
Old May 6, 2011 | 01:49 PM
STL94LT1's Avatar
STL94LT1
How does your mail-order tune work? You send them the PCM, or they send you the file and you reflash?
Old May 6, 2011 | 04:41 PM
Rbuet's Avatar
Rbuet
I datalog and email the log files to PCMFORLESS. They email revised parameters back. I load into car via their upload program, my laptop and cable.
I use TTS Datamaster for logging.
I also have TunerPro RT, but have not used it yet to change parameters. I'm a novice at this and still learning. Soon, I will make small modifications and upload changes to the car via my laptop and TunerPro RT.
In the case of the speedometer, I can't figure out if I have a mechnical problem or a software issue.
Ron
Ron
Old May 6, 2011 | 04:56 PM
STL94LT1's Avatar
STL94LT1
Email me the file and I'll take a look.
Old May 17, 2011 | 01:54 PM
Rbuet's Avatar
Rbuet
Resolution: STL94LT1 went above and beyond to identify and fix the problem. The problem was that my mail-order tune was setup for a camaro, not a corvette. As a result, the parameters for the speedometer were incorrect.
STL94LT1 not only identified the problem, but modified my existing .bin file to correct it and emailed it back to me!
And a side note . . . overall drivability has improved with the correction because the PCM always thought the car was going 1,2, or 3 mph. My low speed stall problem is also fixed.
What a great guy! Thanks STL94LT1!
Old May 17, 2011 | 06:11 PM
aboatguy's Avatar
aboatguy
Good to hear/read that a member hooked you up. I used a PCM for less tune for less than a week........
then I followed Ron's (from AI) advice and gave Ed Wright a call.
I'm sorry to see that folks still send F-body tunes to Y-body owners.
Congrats on getting the performance you paid for.
Mike
Old May 18, 2011 | 09:54 PM
RustInPeace's Avatar
RustInPeace
I think pcmforless may have done the same thing to me, I have stock gears and my speedo reads correct but on TTS datamaster the values are always 0-7, it seems to only display the 1st digit of my speed though, if im going 10-19 it will say 1, 20-29 will say 2, 30-39 will say 3, etc. Right after getting the tune from them my VATS magically decided to not let the car run for more than 3 sec also and I had to have it disabled, I assume this may have been caused by the f body VATS that is different from the Y body VATS I read about, making its way onto my pcm
To Speedometer problem
