4+3 Electrical Connector Identification
Old May 3, 2011 | 09:14 PM
Bucs34's Avatar
Bucs34
Default 4+3 Electrical Connector Identification
Hello, I am currently replacing the 4+3 in my 85 with a TKO 500. The doug nash has 4 electrical connections on the side and I need to identify which ones do what.
Thanks for the help!
Old May 3, 2011 | 09:33 PM
cgantner5150's Avatar
cgantner5150
Starting from the front working back on my 86 4+3: First Gear Lockout, Reverse Lights, then Speedometer
Old May 3, 2011 | 10:24 PM
Bucs34's Avatar
Bucs34
Does your tranny only have 3 plugs? Mine has 4.
Old May 3, 2011 | 10:40 PM
cgantner5150
Put it this way, Mine only had three connections connected.
I just went out and checked and there are only three on mine. One by the 1-2 shifter (middle lever) one above the drain plug (behind the reverse lever) and one on the tail shaft (VSS).
No idea what year my tranny is from (my Vette is a mutt) - it is a an early 86 and I have the TV cable (heard that the 86 on was electrically operated kickdown but mine is an early model). Maybe the other connection is for the kickdown?
Old May 4, 2011 | 08:37 AM
vetteoz's Avatar
vetteoz
Mine has 4.
Number of gear position switches on the side cover varied by year ( all had backup switch and VSS )
1984 cars had 3 switches (1st, 2nd, and 4th ).
1985 , 1987, and 1988 cars had a 1st gear switch
and 1986 cars had none.
Old May 4, 2011 | 08:47 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Overdrive solenoid could be the fourth.
Old May 4, 2011 | 09:26 AM
Bucs34's Avatar
Bucs34
For the TKO I only need to figure out witch plugs are for the speedometer and the reverse light. I would love to see a picture that labels each connector.
To 4+3 Electrical Connector Identification
