Help installing FMS fuel injectors...
Old Apr 19, 2002 | 05:33 PM
Mike263's Avatar
Mike263
Default Help installing FMS fuel injectors...
I'm installing a set of FMS 24# fuel injectors in my L98 - for the second time, hoping to eliminate any chance of a vacuum leak when I'm done.
I have a coulple of question for folks who have done injector R&R.:
1) Do the runner gaskets go on dry, or do you use some kind of gasket goo with them?
2) The o-rings on the manifold side of the injectors don't appear to be as thick as the originals (diameter is OK). Do you use the o-rings that came on the FMS injectors?
TIA
[Modified by Mike263, 3:33 PM 4/19/2002]
Old Apr 19, 2002 | 05:39 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Help installing FMS fuel injectors... (Mike263)
Though I don't know about the O-rings, the runner gaskets go on dry.
Old Apr 19, 2002 | 06:01 PM
Mike263's Avatar
Mike263
Default Re: Help installing FMS fuel injectors... (65Z01)
Thanks.
Old Apr 19, 2002 | 06:19 PM
C4-Wolf's Avatar
C4-Wolf
Are you coating the O-rings w/fresh oil? This should help them seal.
Old Apr 19, 2002 | 09:50 PM
Mike263's Avatar
Mike263
Default Re: Help installing FMS fuel injectors... (C4-Wolf)
Yes, coated with fresh oil. Thanks.
To Help installing FMS fuel injectors...
