Clutch Noise
I've got a suspicion that this problem is more than just in the line.
A couple months ago I started hearing a whistling noise when the clutch is not engaged and the car is in neutral, yet the slightest tap on the clutch pedal and the noise goes away. Any ideas? Anyone had an issue like this before?
I can take a quick video of the noise if it will help anyone.
Thanks in advance for the help.
I'm a college student and could really afford not to do it right now.
1. When you say "the clutch not engaged," do you mean that your foot is off of the clutch? (If so, the clutch is actually engaged. It's disengaged when you release the pedal.)
2. And that when you tap the clutch pedal, the noise then goes away?
If the answer to question 1 is "yes," it's not the pilot bearing.
If the answer to both questions is "yes," my first guess would be that what you're hearing is the release bearing (throwout bearing) kissing the tips of the levers on the pressure plate, and that noise stops when there's enough pressure applied to that interface to cause the release bearing to spin with the clutch, rather than remaining motionless. It could be that the clutch fork is not falling back as far as it should when you're not on the clutch pedal.
Live well,
SJW
Live well,
SJW
If you can't tell I'm a beginner but very willing to learn. I did a bit of reading here.
Engaged
Disengaged
Your saying that the clutch fork is not fully disengaging (when my foot is off the petal) which is causing the release bearing to not get that full range of travel away from the clutch plate. So the release bearing is spinning with the clutch plate, causing the hissing as it spins around hitting the springs on the pressure plate. Am I following you correctly?
If so, what would cause the clutch fork not to fully disengage the release bearing? Slave rod? Or is it just the bearing itself has gone bad and no longer has its full range of travel? Or the springs on the pressure plate have worn down cause it not to move back properly? Again these are all just guesses based on no actual experience whatsoever just looking at the mechanism.
Seriously, your best bet is to get this car to a good mechanic for diagnosis. We can only guess here. This one does not fall into the "no-brainer" category based upon the symptoms.
Good luck with it, and let us know what you learn.
Live well,
SJW
