Crazy interior lights
Old Apr 20, 2002 | 12:18 AM
DC-NH's Avatar
DC-NH
Default Crazy interior lights
On occasion when I turn the car off the interior lights go off and stay off even when i open the door. The surcurity light on the radio clock will stay on (it should go off)
If I open the passenger door the lights go on.
If I put the key in the ignition turn it to start and turn it off the lights will stay on like normal until I leave and close the door.
What's the deal here?
Old Apr 20, 2002 | 01:08 AM
Red Dwarf's Avatar
Red Dwarf
Default Re: Crazy interior lights (DC-NH)
Probably one of your door switches is hanging up. Might try some WD-40, small amount, & see if that helps. :cheers:
Old Apr 20, 2002 | 02:38 AM
weekendwrench's Avatar
weekendwrench
When they dont go on try hitting the passenger side lower dash panel. There is a relay behing the panel but I don't remember what they call it. Mine acts similarly. If I hit the panel the lights will come onwhen the door is open. Hopefully you just have a bad door switch.
Old Apr 20, 2002 | 07:27 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Crazy interior lights (weekendwrench)
Also check your hatch switch, that's what was causing my problems.
Old Apr 21, 2002 | 12:13 AM
Rich_01659's Avatar
Rich_01659
Default Re: Crazy interior lights (Mr Mojo)
your problem may be that the door switch pin is sticking and wd-40 may help...(i've been there).. at first. if you use wd-40 then you will have the reverse problem. the lights will come on when the door is closed and every time you hit a bump. this is because the wd-40 allowed the pin to settle further into the switch. the door switches on the 94 are adjustable. you can pull the pin out a bit and it will make better contact with the car when the door is closed. so do what you have to do to free it up.
To Crazy interior lights
