Cooling Fan Problem
Old May 9, 2011 | 12:46 AM
marvinator's Avatar
marvinator
Default Cooling Fan Problem
BOTH PRIMARY AND AUXILLIARY RADIATOR FANS QUIT WORKING ON MY 1985 VET. ANY IDEAS ON CAUSE WOULD BE HELPFUL THANKS
Old May 9, 2011 | 08:35 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Fan fuse or fusible link near battery. Follow the heavy red wire from main fan relay(inner fender below MC) back towards battery and you will find the fusible links.
Old May 9, 2011 | 01:24 PM
CAJUN C4's Avatar
CAJUN C4
Temp. Switch or Bad Relay. Is it controlled by the ECM or a contact Temp Switch in the Right Cyl. Head?
Old May 9, 2011 | 03:44 PM
marvinator's Avatar
marvinator
THINK I FOUND PROBLEM BAD RELAY THANKS
Old May 9, 2011 | 03:46 PM
marvinator's Avatar
marvinator
Found bad relay thanks
Old May 9, 2011 | 03:51 PM
CAJUN C4's Avatar
CAJUN C4
Good..That's usually what goes first.
Old May 9, 2011 | 04:43 PM
greenbasil's Avatar
greenbasil
Cruising
Default newbie with cooling issues HOT HOT HOT
Hello to everyone. I'm glad I came across this forum as I have an issue that needs to be addressed.
I've got a problem with overheating. both fans do not come on when supposed to EXCEPT when I turn on the AC, then one fan comes on. that has kept me from damaging the motor. This is what I ve done, replaced both relay's as they were old. I can ground each relay making each fan turn on by relay connector F.. i've got voltage at the relays using connector E to ground also voltage at connector D. I can jump terminal A to B and they turn on., i've grounded the fan's and got each one to work.
I've pulled out the ALCL from underneath and I think I've got a problem already. As you look at the ALCL attached to the frame housing , the circular hole is on the right side as you look at the pins, with the oval hole on the left. they should line up in pairs, FEDCBA being the top letters and the bottom are GHJKLM, reading left to right. I have 16 slots with 6 slots EMPTY, and most important the slot for letter B is empty with no wire, as is the location for letter F. I've traced the bundled wires as far up into the dash area as I can and yet there is still 6 wires missing. it appears that someone must of done some monkeying around up there.
My guess is, with the ignition key in the ON position and iv'e ground the inoperative cooling fan relay's (both of them) via connector terminal "F", they turn on, that my problem is with the ECM.
Feedback ? I'm just a home mechanic with available tools and I do not want to take it to a "shop". Thanks for your input.
jason
Last edited by greenbasil; May 9, 2011 at 09:58 PM. Reason: I forgot to mention that I've already replaced the coolant temp sensor behind the oil dipstick tube, passenger side.
Old May 9, 2011 | 05:41 PM
AGENT 86's Avatar
AGENT 86
How does one bad relay kill both fans ?
Old May 9, 2011 | 05:44 PM
AGENT 86's Avatar
AGENT 86
Greenbasil, what year vette?
Old May 9, 2011 | 09:56 PM
greenbasil's Avatar
greenbasil
Cruising
oops forgot. it's a 94 LT1 Coupe with targa top. 6 speed manual.
Old May 9, 2011 | 10:20 PM
AGENT 86's Avatar
AGENT 86
Sorry, not familiar with your year.
If you were pre 90, I could have helped.
Old May 10, 2011 | 10:18 AM
marvinator's Avatar
marvinator
NOT SURE BUT BOTH FUSEIBLE LINKS ARE GOOD AND BOTH SENSORS WORK, ACTUALLY FOUND 2 RELAYS GOING TO REPLACE THEM AFTER WAITING A WEEK FOR THEM TO BE SHIPPED FROM CALIF. EVERYTHING ON MY VETTE IS no longer being made and is no longer available thru G.M.
Old May 10, 2011 | 02:07 PM
greenbasil's Avatar
greenbasil
Cruising
I'm new and I jumped in on this post, perhaps I should start a new one that's particular to my issues?
Old May 10, 2011 | 03:12 PM
AGENT 86's Avatar
AGENT 86
Yes, you will get much more help. Include your year in your thread title, that way members will know right away if they can help.
Old May 10, 2011 | 03:21 PM
greenbasil's Avatar
greenbasil
Cruising
ok. i did make a new post but it disappeared on me. iv'e got to go looking for it. perhaps went in the wrong thread/forum.
To Cooling Fan Problem
