Intermitent "sys" light
Old May 14, 2011 | 04:27 PM
richauto's Avatar
richauto
Default Intermitent "sys" light
I have noticed the sys light flashes. Mostly when the car is cold. I haven't noticed a drivability problem and the light will stay out for a long time. Has anyone had this issue? Thanks,Rich
Old May 14, 2011 | 04:51 PM
STL94LT1's Avatar
STL94LT1
Low battery charge.
Old May 14, 2011 | 05:30 PM
richauto's Avatar
richauto
Originally Posted by STL94LT1
Low battery charge.
Thanks STL94LT1. I have felt my alternator is a little loud. It is charging and the battery doesn't seem weak. However I will take the alternator out and replace it. Also the battery terminals are clean and tight. Thanks again.
Old May 14, 2011 | 05:54 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Before replacing the alternator, have the battery load tested.
You could have a brand new 100% functional alternator, but with a worn out battery you'll still get the SYS light.
Old May 14, 2011 | 07:17 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Find out want is wrong before throwing parts at it.... http://tech.corvettecentral.com/2011...trouble-codes/
To Intermitent "sys" light
