security light on car wont start
Old May 16, 2011 | 03:43 PM
ernurstn1's Avatar
ernurstn1
2nd Gear
Default security light on car wont start
does anyone know how to get car to start that has security on,tried keys in and on for 15 minutes. we are in process of restoring it, so we do not have power locks in they do not work yet we ordered new ones. no steering wheel on getting new on. any suggestions are greatly appreciated.
Old May 16, 2011 | 04:03 PM
ddahlgren's Avatar
ddahlgren
I may be wrong but suspect the door locks and wiring are all part of the security system. So if missing all bets maybe off. Better check the FSM on your un named year.
Dave
Old May 16, 2011 | 05:46 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Did it start before the resto?
VATS controls starter lock out and fuel enable.
Does your key have the pellet?
If so, try cleaning it.
Old May 21, 2011 | 01:18 PM
easyrider41@q.com's Avatar
easyrider41@q.com
Default VATS fix
Drop in at your favorite AUDIO shop, ask them to determine the OHM on your Ign key, then as them for a resistor in the same range, then just unplug the connector from the VATS at the base of the steering column, and insert the resistor into the "car side" of the connector, and tape securely, and you will effectively by pass the VATS. With the resistor in place, your system will think the key is in place, and no more starting problems due to the broken wire in your steering column connected to the ignition switch, which controls the VATS. GG
To security light on car wont start
