85 rough / no idle smokes
May 17, 2011 | 10:37 PM
Cruising
The car stalled out once while diving. i limped it home. since then I have replaced.
fuel filter
distributor rotor "the old one was found to be loose when diagnosing"
injectors
hoses
manifold gaskets
pcv valve
plugs and wires
The car will start but requires that you use the pedal. it will not idle on it's own you must throttle it. It smokes while running.
Any ideas
Thank you
Eric
May 17, 2011 | 10:53 PM
Quote:
Originally Posted by
Ericwp
fuel filter
injectors
hoses
manifold gaskets
pcv valve
plugs and wires
Any ideas
Thank you
Eric
Blue smoke, white smoke....?
May 17, 2011 | 11:02 PM
Cruising
May 17, 2011 | 11:07 PM
Have you checked fuel pressure?
White smoke or blue/black?
How may miles on the car? Cat new?
