Ac problems
Old May 23, 2011 | 06:05 PM
1989erniew's Avatar
1989erniew
Default Ac problems
What to check and where to check ????when ac is on panel i still get a lot coming thru defroster vents fogs up windshield.. Thanks
Old May 23, 2011 | 11:07 PM
myk7's Avatar
myk7
Does changing the setting move the air to other positions? Can you hear a hissing noise?
Old May 25, 2011 | 05:02 PM
crvttbass's Avatar
crvttbass
Cruising
also if it does change from, say floor to top and such, the foam that seals the deflector doors may be gone.
Old May 25, 2011 | 05:49 PM
1989erniew's Avatar
1989erniew
Default ac problem
thank you for your answer very much!!!!
do you happen to know how big a job this is??
Old May 25, 2011 | 08:50 PM
pcolt94's Avatar
pcolt94
Look under the plastic cover on the right side of the engine for a check valve with 3 hoses to it. Check to see if it is cracked or broken and leaking vacuum. If it is bad it is easy to replace and costs $5 - $8 to buy.
Old May 25, 2011 | 10:54 PM
1989erniew's Avatar
1989erniew
Default ac problem
thank you very much
To Ac problems
