anyone know if there are any hiccups to put a 96 lt4 cluster into a 94 lt1. putting in a hot cam and some other stuff and want the higher tach range. any pros/cons would be appreciated. thanks in advance
It should hook up with no problems, just don't throw out or sell your old one, cause i'm sure you'll want to recoupe your $350-400 bucks you'll spend for it. :eek:
Keep an eye out on ebay. I have seen 3 for sale in the past year. Not cheap, but they are there. :seeya The idea has crossed my mind a few times as well.
I dont know if they are interchangable or not....I was looking into doing the same thing, but I read somewhere that you need to have something done with your VATS system. A new chip in you key or what not....
Lingenfelter and Doug Rippie have both been offering this upgrade for several years... I'm assuming what you want is the higher tach reading? Contact either for exact specs but I believe they simply convert your existing dash over to it. In addition I believe they can change the gauge face colors as well...Last I heard it was around $350-400 for the service.
-Jeb Burnett
