Rear Main Cap Question
Old May 25, 2011 | 11:03 PM
megtom2's Avatar
megtom2
Default Rear Main Cap Question
Building an engine and the DVD I was watching told me there should be a plug in one of the holes in this pic. Should they all be open or do I need a plug?? 1990 Corvette engine.
Old May 25, 2011 | 11:06 PM
megtom2's Avatar
megtom2
Of course I know where the bolts go for the cap and the extension for the oil pump but should the last one be capped?
Old May 25, 2011 | 11:23 PM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
I believe there is a check valve or some sort of oriface that goes in one of the holes. I will see if I can dig a picture up. Pretty sure it was mentioned that if it wasn't there, you would see about 20 psi oil pressure.
Old May 25, 2011 | 11:27 PM
myk7's Avatar
myk7
Run a coat hanger up that hole and see how far it goes in. I know the cap is like 8.5 inches from the top (where the oil pressure sensor goes), not sure how far from the bottom. That hole is not supposed to be plugged right there, but up higher in the hole.
Old May 25, 2011 | 11:37 PM
Black89Z51's Avatar
Black89Z51
This is from the Pete K is building me a 383 thread found in the FAQ. It's page 14. There is a reply that mentions the plug later in the thread.
http://forums.corvetteforum.com/c4-t...photos-14.html
Originally Posted by Pete K
It does:
To Rear Main Cap Question
