Oil Leak rear of engine -oil pressure sensor ?
The reason the oil switch and oil pressure sender are where they are is because that oil passage in the block comes directly from the oil pump. Chevy small blocks have had the oil pressure sender there since 1955.
The thing that puzzles me is the EGR tube over the passenger side valve cover. The old carb heat crossover passage still existed in the heads, but was blocked off in the TPI intake manifold. Seems to me they could have used that for EGR. I guess they had their reasons for doing it the way they did, but still...
