New Injector's
Old May 29, 2011 | 08:06 PM
$300vett's Avatar
$300vett
Default New Injector's
Hello everyone..
I hava a 85 stock vette and I am going to replace the injector's , fuel regualator and fuel pump...Does anyone have any suggestion on what type of injectors I should get and also if I go with 30lb injectors would I have to something with my ECM.... Thanks alot...Bo
Old May 29, 2011 | 08:19 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
Jon at FICInjectors is the man to ask your questions. IMO 30# injectors are too big for a stock engine.
Old May 29, 2011 | 08:22 PM
floridamale's Avatar
floridamale
There is no advantage using a 30lb injector with a stock L98. Talk with Jon @ FIC he will get you the right injectors for your car
Old May 29, 2011 | 08:29 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Originally Posted by $300vett
Hello everyone..
Stay with stock flow injectors.
Old May 29, 2011 | 08:36 PM
John A. Marker's Avatar
John A. Marker
The 85 stock injectors were 24#. With all the modifications to my 85, I am still running 24# injectors without issues.
Old May 29, 2011 | 08:40 PM
vader86's Avatar
vader86
No need to change the level from stock for your car unless you have significant modifications that improved the air into it.
Old May 29, 2011 | 09:28 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Stock is 22. I went with 24 and had it retuned to accept injectors larger(24). I also have minor mods and plan on doing larger mods in the future.
Old May 29, 2011 | 11:08 PM
Corvette0096's Avatar
Corvette0096
Jon knows his stuff. I just bought a new set last week. 63LBs.
Old May 29, 2011 | 11:29 PM
cumbercr's Avatar
cumbercr
Jon will most likely recommend the Bosch III 24# injectors that are rebuilt. When I bought them for my stock 85, they ran approx $189.
The Bosch IIIs do a better job of atomizing fuel compared to the stock injectors. If you are installing an adjustable fuel pressure regulator you can increase the fuel pressure a little. The 85's run at a lower pressure than later years. But with the new injectors, the engine will actually run a little leaner. So it will like 3-4 lbs more pressure. TPiS did some dyno runs on an 85 that proved a slight improvement in Hp with the additional pressure.
Good luck. This is a good modification that will improve starting and driveability.
Old May 30, 2011 | 01:29 AM
vader86's Avatar
vader86
Stock is 24 in 1985, though the spec rating is at a different PSI than 86 and later, it is a different injector.
Old May 30, 2011 | 09:04 AM
BADDUCK's Avatar
BADDUCK
Exactly, don't put in low lb/hr injectors either and hope the pressure will make them work, it won't. Stick with true 24# in your car.
Old May 30, 2011 | 01:47 PM
jan-erik's Avatar
jan-erik
MJL the 85 is stock with 24 lbs/hour the 1986 and newer is 22lbs
Old May 31, 2011 | 09:49 AM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
Exactly right, on the L98 motors 85 is 24, 86-91 is 22, LT1 is a 24, LT4 is a 26.
Old May 31, 2011 | 09:21 PM
$300vett's Avatar
$300vett
Thanks for the info...I sent you an email about what type you would reccomend.... my email is mike.bohanon.ext@areva.com thanks Bo
ps.. to all that responded thanks....
To New Injector's
