85-89 MAf info needed>>
Old Apr 22, 2002 | 09:52 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default 85-89 MAf info needed>>
what is the length of the 85-89 MAF. I know the Diameter but need to know the length and I forgot to measure that. I am planning on picking up a piece of Tubing to fit inplace of the MAF..since I am running Speed Density..
THANKS
Old Apr 22, 2002 | 10:09 AM
Bill Reid's Avatar
Bill Reid
Default Re: 85-89 MAf info needed>> (tntcorvette)
Between 3 1/2 and 3 9/16"... I'll be doing the same thing soon enough... will probably do SD upgrade when I go to LT1 converted intake.
Old Apr 22, 2002 | 10:41 AM
-=Jeff=-'s Avatar
-=Jeff=-
just get a traffic cone, and cut it to size from the throttle body to the stock air filter housing. I had to cut the 2 clamps that hold the maf to the housing to the traffic cone would fit flush.
Mine is sealed from the bottom and it seems to work great.
But, mabey lonely traffic cones on the street are a rarity your way.....
:troll
If no one else replys i'll measure a spare maf when I get home.
Well I want a quick fix.. I am going to buy the PVC on the way home.. That is the last piece I need for the motor.. Then I can close the hood :D
Old Apr 22, 2002 | 04:26 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: 85-89 MAf info needed>> (-=Jeff=-)
It's 3 1/2" ridge-to-ridge and 4 3/4" end-to-end.
Old Apr 22, 2002 | 05:16 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: 85-89 MAf info needed>> (65Z01)
THANKS
:cheers:
To 85-89 MAf info needed>>
