M6 Shifter Question
Old Apr 22, 2002 | 10:04 AM
kingvet's Avatar
kingvet
Default M6 Shifter Question
Hey guys, My shift **** on my 1996 coupe is loose and rattles while I am driving. Is there a screw to tighten the **** somewhere. I looked and cant find it. Any help would be great this is driving me crazy. :seeya
[Modified by kingvet, 2:05 PM 4/22/2002]
Old Apr 22, 2002 | 10:08 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: M6 Shifter Question (kingvet)
I'm going to assume it's the stock shift ****.
Pry the plastic shift pattern button out and see if you have a "T" shaped wedge in there. If that is missing or somehow broken(would be pretty hard to do), that could be your problem.
The **** just twists on and the wedge holds it from spinning.
Old Apr 22, 2002 | 10:18 AM
kingvet's Avatar
kingvet
Default Re: M6 Shifter Question (Mr Mojo)
Old Apr 22, 2002 | 04:10 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
There is also a small allen screw on the reverse lockout collar. That might be what is rattling also.
It's on the side facing away from the radio. If you put the shifter into 3rd, you should be able to see it.
Old Apr 22, 2002 | 07:48 PM
JasonL's Avatar
JasonL
Default Re: M6 Shifter Question (Jeffvette)
There's no reverse lockout on the '96 shifter. :)
To M6 Shifter Question
