Help understanding 4+3
Old Apr 22, 2002 | 07:35 PM
BAdAzZV8's Avatar
BAdAzZV8
Default Help understanding 4+3
I'm not sure exactly what it is, but I was thinking it was a 4 speed with 3 overdrives. But is it on manual cars or auto's? Also how does it engage the gears, and can someone show me a pic of the shifter?
Old Apr 22, 2002 | 07:40 PM
scorp508's Avatar
scorp508
The 4+3 is a manual transmission. It has a 4-speed Borg Warner Super T-10 transmission, and a 2-speed automatic bolted to the back of it.
You have 7 gears to choose from.
1st
2nd
2nd/OD
3rd
3rd/OD
4th
4th/OD
The shifter is nothing special. It is your everyday 4-speed shift patter with reverse in the upper-left. 84-85 Early models have a rocker switch on the center console to turn the OD program on and off. 85L-88 models have the switch actually in the top of the shifter. You press the shift pattern to turn the OD program on and off.
Old Apr 22, 2002 | 08:16 PM
BAdAzZV8's Avatar
BAdAzZV8
Default Re: (scorp508)
So if you engage the switch, then OD automatically engages in 2nd gear/3rd gear/4th gear when in the right rpm range?
Old Apr 22, 2002 | 08:17 PM
scorp508's Avatar
scorp508
You got the idea! :)
Also for certain years (84, 86-88) if you stand on the gas it will automatically downshift out of overdrive for full acceleration. It's really handy on the highway or playing with other drivers. :reddevil
Old Apr 22, 2002 | 08:23 PM
BAdAzZV8's Avatar
BAdAzZV8
Cool, thanks man.
To Help understanding 4+3
