How can I test the shocks?
Old May 30, 2011 | 04:46 PM
Narnian's Avatar
Narnian
Default How can I test the shocks?
I have a good friend working on my 1990 Coupe which has been in storage for about a year and a half on the opposite end of the country from me. He is telling me that it needs new shocks, and I'm generally inclined to agree with his assessment over mine mechanically, but I'm wondering if he just isn't used to the stiff ride of a C4.
I'm pretty sure that the shocks are the ones that came from the factory, but I can't remember for certain. He hasn't said anything about them leaking. Is there a simple test to tell if it's just a stiff ride or if it's bad shocks?
Old May 30, 2011 | 11:32 PM
jfb's Avatar
jfb
Push hard quickly and several times on front and rear of car to get it moving up and down and let go. If the car makes more than 1 and 1/2 bounces, the shocks are worn out. Drive a vette with good shocks and then drive yours, bad shocks are obvious.
Old Jun 3, 2011 | 06:43 PM
Narnian's Avatar
Narnian
Thanks JFB! Now that you mention it, I seem to remember my father giving me the same advice about 20 years ago.
My buddy took another look and thinks it's the bushings, not the shocks.
Old Jun 3, 2011 | 08:23 PM
383vett's Avatar
383vett
Worn shocks would make the ride softer, not harder.
Old Jun 3, 2011 | 08:38 PM
leesvet's Avatar
leesvet
If you're shock shopping...don;t go cheap !
you get exactly what you pay for in shocks. The general consensus is to use Bilsteins...they're yellow, they're expensive @ $75- $100 each but they are gaurenteed to be the best available and they can be set up for your driving style. Rebuildable too. Stay away from KYB...Kill Your Back. THOSE are hard shocks,....
Old Jun 4, 2011 | 01:19 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by leesvet
If you're shock shopping...don;t go cheap ! you get exactly what you pay for in shocks. The general consensus is to use Bilsteins...they're yellow, they're expensive @ $75- $100 each but they are gaurenteed to be the best available and they can be set up for your driving style. Rebuildable too. Stay away from KYB...Kill Your Back. THOSE are hard shocks,....
You had me until your comment on KYBs..
KYB's are NOT HARD.
They're just plain SOFT! And IMHO, junk!
A good price for Bilstein sports is $C per corner. And thats cheap if you can find it.
If the shocks are >10 years old or >50,000 miles, just change them.
Old Jun 4, 2011 | 04:10 AM
navy_vette's Avatar
navy_vette
KYB's are NOT HARD.
Remember, if you go cheap now, you will pay in the end. Get a good set of shocks that will last you a long time. Be careful, because once you start upgrading suspension you will realize that it is the easiest and cheapest way to get that driving thrill. Taking a corner and the car sticking where it never stuck before is an amazing feelings. It starts with shocks, goes to better sway bars, then frame stiffening, better tires (I'm in Italy and I'm going to get some P-Zeros soon) and so on and so forth.
It's up to you what shocks you get depending on road conditions, how you drive your car, and how often you drive the car.
Me? I automatically avoid anything that isn't fresh and open road. I don't drive it much and when I do.... I'm not going to incriminate myself.
Good luck!
Old Jun 22, 2011 | 04:06 PM
Narnian's Avatar
Narnian
The shocks were fine, it was the bushings. But to resolve the problem I bought cheap-o Autozone shocks. I thought I had Bilstein in there to start with. Turns out they were Monroe. I've got other things to fix right now so I'll wait tilll the fall or next spring and buy some Bilsteins. RIght now I need to spend some money buying bushings for the rest of the suspension. Just about every bushing on the car is worn out.
Old Jun 22, 2011 | 05:47 PM
vader86's Avatar
vader86
If you can stand some squeakiness, then get poly bushings. If you want ride comfort and to replace them again in 15 years, get rubber.
You'll have to lube the polys often if you dont want them to squeak.
Old Jun 22, 2011 | 06:00 PM
Repzard's Avatar
Repzard
Make whoopy( keeping it clean) in the Corvette with your women and if it bounces alot.
you need shocks
Old Jun 22, 2011 | 06:15 PM
Narnian's Avatar
Narnian
If we can still buy gas and drive gas powered cars in 15 years, I'll probably give it to my son. Squeaky bushings means he can't make out quietly in his car when he is supposed to be alone in his bedroom studying. Poly it is!
Of course, I've noticed that making out in a C4 is nearly impossible.
Old Jun 22, 2011 | 06:16 PM
c4zf6nut's Avatar
c4zf6nut
Did you replace Monroes with other Monroes? I am interested ot hear what you think of them. Prothane bushing kit is inexpensive, I had Energy in my Civic for three years and it did not squeak at all. I wonder if Prothane sequeaks. I have the kit but my bushings are fine (so says the mechanic).
Old Jun 22, 2011 | 06:20 PM
Repzard's Avatar
Repzard
Corvettes will be electric by then
Old Jun 22, 2011 | 08:04 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
fact
Old Jun 22, 2011 | 08:11 PM
vader86's Avatar
vader86
Worn shocks will cause a multitude of issues. Body roll becomes more noticable. The ride quality is more erratic - can get harsher because the shock is no longer damping vibrations due to road imperfections, so when you hit a hole the car just keeps right on jittering. It'll also be prone to losing traction as a result.
Steering differences due to the change in bound/rebound is harder to describe in words, but when you have to constantly overcorrect in turns, its a telltale sign. That and body roll can be other things, but shocks do contribute.
To How can I test the shocks?
