Does This Sound Like an OPTI Issue??
Old May 31, 2011 | 11:10 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Default Does This Sound Like an OPTI Issue??
My dad and I tried to autocross his '92 Z07 6-speed yesterday. He went first and was able to make 2 out of the 4 runs and then the engine started missing and popping. It also got very hot, so we started looking for issues. The secondary fan does not come on so that would explain why it gets hot, but it only pops and misses when it is hot. By the time I tried to drive it it would miss and jerk and pop with any kind of load (just getting started from a stop it wanted to stall). After letting it cool all day it drove home fine with full power, but on the highway following other cars it got hot again and started missing.
I have heard upgrading to a vented opti is best? What would be a good replacement for my dad's '92? Is there anything else that should be done while we are in there? I assume the water pump and thermostat gasket since those are prone to leaking and killing optis. The car has almost 150K miles on it and we have not done anything to it since my dad bought it last year.
Old May 31, 2011 | 11:15 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
How hot is hot? Is it low on coolent?
Old May 31, 2011 | 11:18 AM
STL94LT1's Avatar
STL94LT1
Upgrading to an OEM vented opti components:
95/96 opti
95 timing cover
opti wire harness
opti vacuum harness
camshaft
Old May 31, 2011 | 11:41 AM
Kubs's Avatar
Kubs
Coolant was 230-240 or so. It was full of coolant. The secondary fan stopped working thats why it got so hot.
95/96 opti
95 timing cover
opti wire harness
opti vacuum harness
camshaft
I thought MSD made an opti that was vented for the early non vented cars? This is just his daily driver that we drove for fun yesterday because the race car isnt done yet. We dont want to have to change a cam if we dont have to.
Edit: This MSD unit at Summit is vented, and is made for the early style opti.
http://www.summitracing.com/parts/MSD-8381/
By the time I buy all the OEM vented components I would have spent as much as a nice MSD opti, unless the MSD unit isnt that great? Should I just get a new GM one? I dont want to have to replace this again.
Old May 31, 2011 | 12:14 PM
STL94LT1's Avatar
STL94LT1
I've heard good and bad about the MSD opti's.
You can also buy a kit to vent the Gen I OEM opti.
Old May 31, 2011 | 12:23 PM
rklessdriver's Avatar
rklessdriver
The MSD is a good unit.
My personal experience has been that checking the O-Ring/Seal on the cap (make sure it's seated correctly) and inspecting then loctiting the rotor screw will solve 99% of problems people who take them out of the box and install them without checking anything have with it.
Will
Old May 31, 2011 | 12:35 PM
Kubs's Avatar
Kubs
Do you have a source or link for this kit?
Will
Thanks for the tip Will.
Im an L98 guy so I only know what others have talked about on here about optis.
Old May 31, 2011 | 12:53 PM
hgh pwr's Avatar
hgh pwr
the msd is more expensive and if you don't plan on modifying the car stay with the stock g.m. piece you will be much happier.
Old May 31, 2011 | 01:24 PM
0Paul Ruggeri
Former Vendor
Your car should not run 230-240 on the highway even if both fans don't work. That's OK in at low, no speeds, if the fan comes on and brings it down. On the highway you'll have enough airflow without the fans.
Old May 31, 2011 | 02:11 PM
Kubs's Avatar
Kubs
Thats was racing temp. I dont know what it was on the highway (dad was driving) but it was hot enough to make the car start missing.
Old May 31, 2011 | 02:12 PM
Kubs's Avatar
Kubs
How much/where can I find a GM unit? I thought they were around $400? Thats why I thought is would be better to go MSD for the money.
Old May 31, 2011 | 02:27 PM
jmgtp's Avatar
jmgtp
I'd consider the coil or ICM getting heat soaked and causing those problems before the opti. It happened to me and the ICM was the culprit. Would only do it once the engine got good and hot.
Also, how much gas did you have? These cars slosh the fuel away from the pickup when the tank gets low. If I try to accelerate hard with only a few bars of fuel on the gauge the engine will studder. It will do this well before the reserve light comes on.
Old May 31, 2011 | 02:43 PM
Kubs's Avatar
Kubs
How much was the ICM to replace? Where is it located on the LT1?
My '90 does the same thing. We had a full tank. It definitely felt like a spark issue not a fuel issue.
Old Jun 2, 2011 | 08:40 AM
jmgtp's Avatar
jmgtp
The icm is the module located next to the ignition coil. Look near the power steering pump reservoir. Aftermarket (autozone etc) icms are around $100 I believe. I had really bad luck with junk aftermarket icms, my suggestions would be to have it tested and if determined to be defective find a used or oem replacement.
After much frustration with bad coils and icms I switched over to ls1 coil packs using the ltcc unit (still uses opti signal but not the high voltage side). I've had zero ignition problems since then and still use m factory original opti.
Old Jun 2, 2011 | 12:16 PM
Kubs's Avatar
Kubs
Thanks for the tips. I will check out the ICM before looking for other parts.
I looked into the coil pack deal and it gets pretty pricey. My dad just wants to drive the car. Mine is the one being built for racing.
Old Jun 2, 2011 | 03:43 PM
ScaryFast's Avatar
ScaryFast
Kubiak PM me your email, I have lots of documents I can send regarding the vented kit, '95 upgrade, and a nice troubleshooting step by step guide for checking if your opti, ICM, and coil are good or bad.
If you do end up needing an opti I can do it in about an hour now...although I'm a bit rusty as mine doesn't eat them up anymore.
Don't buy the MSD. If you want mine you can have it cheap, it's been sitting on the bench for two years...oh, did I mention it failed just as easily as the stock ones?
Old Jun 3, 2011 | 08:18 AM
firstlt4's Avatar
firstlt4
Cruising
I've been having similar problems with my 96 LT4, it actually won't start at all now, fuel pressure is 47, seems to have no spark out of coil or opti,,, does anyone know what is first in line - the coil or the opti? I need to know how to test the ICM? can anyone help...
it sucks coming out of turn 1 at pocono and the engine dies....
To Does This Sound Like an OPTI Issue??
Old Jun 3, 2011 | 12:22 PM
rob-cyn's Avatar
rob-cyn
My ICM gave me the same issues you are having. See if you can loan one and try it. Also, my fans used to run all the time even when not needed, I cant explain it but since I put a brand new ICM on it has quit doing that.
Old Jun 3, 2011 | 12:23 PM
rob-cyn's Avatar
rob-cyn
Autozone checked my ICM. Not all of them know how, but I found one.
Old Jun 3, 2011 | 01:45 PM
firstlt4's Avatar
firstlt4
Cruising
thanks, the autozone by me is usually good, they have a few people in there into performance and racing,,,, I'll check into the ICM further, never had an issue with the fans running though.
