Slipping when warm?
Old Apr 22, 2002 | 01:29 PM
devilfish's Avatar
devilfish
Default Slipping when warm?
Today I did som hard runs around a track with my vette. And I noticed that my tranny act a bit diffrent after the run.
It seems that it has a problem to downshift right. I whas in third going uphill and pressed the throttel down a bit, the tranny refused to downshift to second?! And then I tried to punch it, now it shifted down to first gear ( as it should ) but the car dident throw me back in the seat as it used to to, just like the tranny whas slipping... After letting the car cool down the tranny works like it should, downshifts are nice and the car pulls as it should.
Do I look at a rebuild? Or can a fluid and filter change help me?
Or a tranny cooler?
I hope you can help me..
ohh and the fuild is the right colour and doesnt smell burn.
Regards
Old Apr 22, 2002 | 01:59 PM
devilfish's Avatar
devilfish
Default Re: Slipping when warm? (devilfish)
tt
Old Apr 22, 2002 | 02:22 PM
KYVette90's Avatar
KYVette90
I would go with a fluid and filter change if it hasn't been done in a while. If that dosn't work then you should probably think about a rebuild. :cheers:
Old Apr 22, 2002 | 02:33 PM
Mark 84ltblu's Avatar
Mark 84ltblu
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
Default Re: Slipping when warm? (KYVette90)
Excellent advice. If it doesn't smell and it isn't discolored. This may keep you going for a while. Eventually they all need to be rebuilt and the more you run them on the track, the quicker that time comes.
Old Apr 22, 2002 | 02:42 PM
devilfish's Avatar
devilfish
Default Re: Slipping when warm? (Mark 84ltblu)
whas my tranny slipping? And If I change fluid + filter and mount a tranny cooler, can I prevent this from happed again?
Old Apr 22, 2002 | 04:08 PM
devilfish's Avatar
devilfish
BUT if I rebuild my tranny. Wount this happend again? As soon my tranny goes warm its going to slip? WHat is your advice for me here rebuild and ad a tranny cooler? Or just ad a tranny cooler now and change filter and fluid?
Regards
Old Apr 22, 2002 | 07:19 PM
vader86's Avatar
vader86
start with fluid and filter, check the color of the fluid and see if there are alot of metal shavings in the pan. If the color aint red and there are alot of very fine shavings in there you should think about a rebuild. When you get the rebuild put a cooler in, or if it just turns out that you needed to change the fluid put one in anyway.
Old Apr 23, 2002 | 03:37 AM
devilfish's Avatar
devilfish
Default Re: Slipping when warm? (vader86)
ok.. SO is it normal that a healty tranny slips when it get hot enough?
And how do I get ALL of the fluid out off the tranny?
Regards..
To Slipping when warm?
