hood wont open
Any Ideas? I am really stumped on this one
- Remove fender
- Get a coat hanger and make a hook
- Introduce your hand thru the space between your fender and wheel well
- Introduce the hook from the wiper area,then catch it with your hand and guide the hook to the latch,till you engage them
- Stand up and pull to the center of the car,that should open your hood
- Now never forget to add emergency cables
ps : i have a bad driver side cable retainer and one day it popped out leaving the cable loose and hood closed (all of this after i had the remove fender experience)
it was a real let down..but i remembered that i had emergency cables !!!!
Wow i was happy,i pulled them and HAPPY HOOD OPEN AGAIN
The hanger has to be hard enough to pull but soft enough for you to acommodate every angle every try,here ya go,this is how i opened mine,the work of your left hand guiding it to the latch is very very important,thats the reason you have to get familiar with the latch's location :
Here you go !
This is what the tool does :
Now you need this :
http://www.mamotorworks.com/corvette?frame=1.8064
Or just do it yourself :
http://forums.corvetteforum.com/c4-g...with-pics.html
Let us know !
Curse loudly (repeat as needed)
Threaten to sell this *^&* Piece of S*&%
Then it will pop right open
Zip ties are already in place
