Swap
Old Jun 4, 2011 | 09:29 AM
SRS1127's Avatar
SRS1127
Default Swap
I HAVE A 96 LT1 CONV. 15000 MILES TRANS. SLAM OUT OF GEAR AT HIGH RPM'S DURING TAKE OFF. ANYONE HAVE SAME PROBLEM..I HAVE A 96 LT4 MOTOR AND TRANS SITTING HERE. HAS ANYONE EVERY DONE A SWAP MOTOR AND TRANS OR HAS ANYONE JUST CONVERTED A AT TO MT ANY ADVICE OR HELP WOULD BE GREAT..
Old Jun 4, 2011 | 10:51 AM
HlhnEast's Avatar
HlhnEast
Welcome to the Forum. Your question is been covered thousands of times in very technical detail. Folks here have mated many tranny to many motor options and documented it all here.
There is a "SEARCH" button in the middle of the tool bar, click it then click "advance search" Enter your specific search terms then scroll down to see the different forum options. Check C4 Tech/Perf for where the engine to search. Then read for the next month, then ask specific questions here in a NEW thread. Dont drag up a post from 6 years ago.
Good luck!
Old Jun 4, 2011 | 01:19 PM
383vett's Avatar
383vett
It "slams" out of gear? Does that mean it goes from 1st to neutral? Does it slam into 2nd gear? Some clarification will help.
Old Jun 5, 2011 | 07:38 AM
HlhnEast's Avatar
HlhnEast
Originally Posted by 383vett
It "slams" out of gear? Does that mean it goes from 1st to neutral? Does it slam into 2nd gear? Some clarifiacation will help.
I know when a tranny pops out of gear under torque it sounds like a sledge hammer slamming into the car
Old Jun 5, 2011 | 09:02 AM
383vett's Avatar
383vett
On my car if I'm at full throttle and shift from a gear to neutral (haven't really done this), the car just stops accelerating and the rpms skyrocket. I don't get the sledgehammer effect.
Old Jun 5, 2011 | 02:17 PM
SRS1127's Avatar
SRS1127
At 5000rpm slam out of low n freewheels till rpm lower and reengages.
Old Jun 6, 2011 | 10:08 AM
SRS1127's Avatar
SRS1127
I not shifting... It when the car shifts from first to second it give you the feeling that someone pulled the driveshaft out then as rpm's fall they slide it back in..i would like to convert to stick bc i have one here on the shelf..anyone have any exp..doing this..would like to know if its a pain in the ***...
Old Jun 6, 2011 | 10:23 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
What year is your car?
Is the motor and trans out of a Corvette?
If so at min you'll need pedal assy, clutch master, drive shaft, C-beam.
The dayna33 isn't know for its longevity behind HP/tq, so you may want to find a dayna44
Then all the work to remove and install the 96 parts. If you don't have a 96 you'll need a computer, ccm, wiring harness, hope, luck, perseverence
Not trying to discourage you but the wiring alone would be a big pain unless you are starting with a 96.
Old Jun 6, 2011 | 10:56 AM
SRS1127's Avatar
SRS1127
I have a 96 and i have 96 lt4 parts car so everything should work..would you do it...
Old Jun 6, 2011 | 11:29 AM
STL94LT1's Avatar
STL94LT1
Why not, if you have all the parts. Is the donor car beyond repair?
Old Jun 6, 2011 | 11:37 AM
SRS1127's Avatar
SRS1127
Lol....no not even close..looks like he did alot of work to the lt-4 motor and was showing off and rolled it over..would you swqap motot and trans or just the trans
Old Jun 6, 2011 | 12:39 PM
STL94LT1's Avatar
STL94LT1
I would swap engine, trans, and rear end!!
To Swap
