operating temp.
Old Jun 6, 2011 | 02:28 PM
msc61's Avatar
msc61
5th Gear
Default operating temp.
hi, new here. im sure this has been discussed. what is the normal operating temp on a 93 LT1? the gauge is at 3/4 and dig temp is at 230/235. thats in stop and go traffic @ 85 degrees. seems hot to me.
Old Jun 6, 2011 | 02:39 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
That's normal. You should hear the fans kick in at about 220, and then the temp should drop. Or if you leave your AC on, the fans will always be on.
Check the area between the rad and the condenser, and clean out any debris you find in there. Tons of threads on this topic. The search function is your friend.
Old Jun 6, 2011 | 04:33 PM
TWISTERUP's Avatar
TWISTERUP
primary fan should be on around 220*---secondary on around 226*-227*---one or both should also run w/AC on depending on pressures. If the fans do run and you have 230-235* as stated above check for road debri partially blocking air flow through the condenser and radiator.
Old Jun 6, 2011 | 07:27 PM
msc61's Avatar
msc61
5th Gear
thanks for fast reply. im just a worry wart. been hot as heck here lately.
Old Jun 6, 2011 | 08:25 PM
SunCr's Avatar
SunCr
For any car: Non a/c: Whatever set temperature is burned into the Programming from the Coolant Temp Sensor to turn on the Main and/or Secondary Fan, is the Temperature the fan(s) should turn on at. The increased air flow from one or more fans should drop the Coolant Temperature. If it stays the same or rises, it's messed up. For a/c: Whatever pressure is burned into the Programming when signaled from a Switch or Pressure Sensor screwed into the High Pressure Line, the fan(s) should turn on and the Pressure should drop. If it doesn't, something is messed up. Easy to diagnosis or allay concerns with a Scan Tool (which on Pressure Sensor cars displays the Coolant Temperature and Pressure from the Pressure Sensor). On cars with a Pressure Switch, you need a Manifold Gage Set along with a Scanner.
Old Jun 9, 2011 | 06:13 PM
msc61's Avatar
msc61
5th Gear
well, it was almost 100 degrees yesterday and we were out. temp went up to about 235 and then went down to 215 in traffic. a real trooper. it was hot out. i wouldve overheated.thanks for all info.
To operating temp.
