Replace Input bearing in 6 speed
Old Jun 7, 2011 | 01:51 AM
Ralphbf's Avatar
Ralphbf
Default Replace Input bearing in 6 speed
My 6 speed tranny input bearing is making some noise.
How hard is it to replace?
I've replaced them on 3 and four speeds before, 40 years ago.
Is this transmission similar in that manor?
Ralph
Old Jun 7, 2011 | 11:44 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Are you talking the throw out bearing?
unobtanium - however if you find one new without buying the whole clutch kit let us know!
IIRC the tricky part is the corvette is a pull type clutch, those older ones were push type.
Old Jun 8, 2011 | 02:14 AM
Ralphbf's Avatar
Ralphbf
I'm talking about the bearing on the input shaft.
The shaft in the transmission that goes through the clutch disk.
Mine seems to be a little noisy and I want to replace it before it does something bad.
Ralph
Old Jun 8, 2011 | 02:23 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
there is a (solid) pilot bearing that sits on the nose of the input shaft and there's a (smaller bearing-filled) throwout bearing that presses on the pressure plate to disengage the clutch.
You're probably talking about the later?
If so...The response about unobtanium would be your relevant reply.
Old Jun 8, 2011 | 07:17 AM
Ralphbf's Avatar
Ralphbf
I'm talking about the bearing that sits inside the transmission on the input shaft. It's usually about 4 inches in diameter.
On other transmissions I've worked on it's pretty simple to R&R that bearing, but on others it's not easy at all.
Ralph
I did not realize that the throw out bearings and pilot bearing were so hard to find outside of a complete kit.
Old Jun 8, 2011 | 11:41 AM
GREGGPENN's Avatar
GREGGPENN
Originally Posted by Ralphbf
I'm talking about the bearing that sits inside the transmission on the input shaft. I did not realize that the throw out bearings and pilot bearing were so hard to find outside of a complete kit.
Inside the transmission? You're talking about an internal bearing for the transmission? If so, I'd contact the ZFDoc to source that.
Or, take it to a bearing supplier.
Old Jun 8, 2011 | 12:38 PM
cv67's Avatar
cv67
St. Jude Donor '05
Trans shop that specializes in sticks, ZF trannies or google for awhile.
To Replace Input bearing in 6 speed
