Here's that TV cable I was asking about
Old Apr 22, 2002 | 11:01 PM
cprgmr's Avatar
cprgmr
Default Here's that TV cable I was asking about
As I suspected, you detach the TV cable from the valve body (duh). Here it is!
[Modified by cprgmr, 9:01 PM 4/22/2002]
Old Apr 22, 2002 | 11:16 PM
RocketSled's Avatar
RocketSled
Default Re: Here's that TV cable I was asking about (cprgmr)
Cool. That was helpful!
Old Apr 22, 2002 | 11:42 PM
cprgmr's Avatar
cprgmr
Default Re: Here's that TV cable I was asking about (RocketSled)
Well, if it helps at least one other person, it was well worth it! :yesnod:
Old Apr 22, 2002 | 11:44 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I think it will help more than one.
Old Apr 23, 2002 | 06:26 AM
tommelton's Avatar
tommelton
Default Re: Here's that TV cable I was asking about (Mr Mojo)
Wrongo on disconnecting it there. The TV cable can be removed without dropping the pan. Disconnect the clip and slide the cable off the pin on the throttle body. Then you will have enough slack to lift the cable housing near the transmission, and you will find the real TV cable linkage there.
The connection at the bellcrank inside the pan area is a small wire about 2" long that connects to the TV cable.
Your attempting it the hard way.
Tom Melton
82 CE
86 Z51 Coupe
Old Apr 23, 2002 | 08:58 PM
cprgmr's Avatar
cprgmr
Default Re: Here's that TV cable I was asking about (tommelton)
Tom Melton
82 CE
86 Z51 Coupe
Thanks for the info - I'll have to check the linkage tomorrow as I didn't see any when I detached the cable. Hard way or easy way, that darn cable is off at the tranny! :D
Old Apr 23, 2002 | 08:59 PM
cprgmr's Avatar
cprgmr
Let's hope so, apparently I did it the hard way (but hey, at least it got done). :)
Old Apr 23, 2002 | 11:04 PM
tommelton's Avatar
tommelton
Hard way/easy way - does not matter. You got it done. GM did not design it with pan removal in mind to replace the TV cable. :)
Now, TV cable replacement on a Superam intake require removal of the intake box. UGH.
-Tom
Old Apr 24, 2002 | 09:10 AM
Jim85IROC's Avatar
Jim85IROC
Ugh. That brought back too many bad memories. I had my pan off my 700R4 so many times the local parts store started stocking extra gaskets for me. :cry
I was never able to get the TV cable off without dropping the pan though. There isn't even enough room for me to get 2 fingers between the trans and the tunnel on my Camaro. Maybe there's more room on a Y-body.
To Here's that TV cable I was asking about
