Air Conditioning
Old Apr 22, 2002 | 11:14 PM
November Soul's Avatar
November Soul
Default Air Conditioning
Some questions,
First off, on a couple of occasions my "Service Engine Soon" light has come on and the engine has died after starting the car when the a/c was on high - is this common?
Secondly, after the a/c has been on for a while, when I park up and turn the engine off, there's a fairly loud hissing from under the hood that lasts for about 10 seconds (not enough time for me to get out and pop the hood) - is this normal?
Thirdly, it hurts when I pee, is this normal?
Old Apr 22, 2002 | 11:38 PM
Rich_01659's Avatar
Rich_01659
Default Re: Air Conditioning (November Soul)
:lol: ok first of all when you pee, is the car running? :lol:
as far as the ac my guess is - not common. i don't have the same model year as you but it sounds uncommon. have you been charging you own ac. just a thought , it sounds like it may be over charged. the hissing is most likely internal, pressure equalizing in the ac system. the stalling - if your ac is running a really high head pressure it could put a strain on the motor and maybe cause it to stall.
good luck
Old Apr 22, 2002 | 11:41 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
going to move this to tech.
Old Apr 23, 2002 | 01:49 AM
hotwilzz's Avatar
hotwilzz
you might also replace the orafice tube filter on the ac system. if this is clogged, it will vent very loudly thru a pressure release valve
good luck david
To Air Conditioning
