Quick L98 timing question......
Old Jun 10, 2011 | 06:52 PM
69SSC5's Avatar
69SSC5
Default Quick L98 timing question......
set timing per factory spec to 6*btdc. take the car to get state inspection and it fails, guy says its because my timing is set to 14* so i take the car home and check the timing, its set at 6*..... am i doing somehting wrong or is he retarted,,,, he has one of those fancy timing lights with the dial on it, i have a plain jane autozone inductive timing light.....
PLEASE ADVICE
yes i disconected the wire when i checked and set timing,,, and so did he
Old Jun 10, 2011 | 08:52 PM
Muffin's Avatar
Muffin
I would trust your simple light before I would his. To solve your immediate problem take it to a Chevy dealer, explain your problem and ask for a timing check. I'll bet the Service Manager will do a check for free. If I am correct this will be the only thing you will ever get for free from a dealer.
Old Jun 10, 2011 | 09:40 PM
l98tpi's Avatar
l98tpi
Max G’s
Just a hunch, but did he check your timing with oyur distributor connected to the ecm or did you set the timing with the lead connected? If the distibutor is not disconnected when checking or changing base timing, it will be different.
Old Jun 10, 2011 | 09:59 PM
eaglevision993's Avatar
eaglevision993
Maybe your balancer has slipped and therefore your timing shows 6 deg while it actually is at 14.....just a guess
Old Jun 10, 2011 | 10:18 PM
69SSC5's Avatar
69SSC5
I took the car back to him and brought my timing light. I showed him it read 6*btdc, he scratched his head. I asked him how he came to 14* he said he thought each notch was 20*... and he also had the dial on his fancy timing light in the wrong place.
I don't really like people touching my car, I am this cars mechanic, this just re affirmed why
Old Jun 10, 2011 | 10:28 PM
John A. Marker's Avatar
John A. Marker
And now that you know that this guy can't read his own timing light....you are going to trust him to do a SMOG check????
Not only can't he read the light, but the timing notches are MARKED.. at "0" and then 4 degree increments before and after!!! OMG
Old Jun 11, 2011 | 03:31 PM
69SSC5's Avatar
69SSC5
Im actually kinda pissed about it.... i will not be returning there
Old Jun 11, 2011 | 04:41 PM
Joe C's Avatar
Joe C
sounds like the idiot falls into the "room temperature IQ" segment of society. he really should be flippin' burgers instead of performing emission testing, but then again, i really don't want him touching my food either...
Old Jun 12, 2011 | 04:14 PM
Mustang_Eater's Avatar
Mustang_Eater
This is why no matter what my issue is I research it online and do the work myself. Can't trust any mechanic.
Old Jun 12, 2011 | 06:01 PM
383vett's Avatar
383vett
I asked why this guy was an idiot from your other post. Now I understand why.
Old Jun 12, 2011 | 06:15 PM
ex-x-fire's Avatar
ex-x-fire
What part did you fail? NOX? Hydrocarbon?
Old Jun 12, 2011 | 06:22 PM
69SSC5's Avatar
69SSC5
Barly passed the HC test at the 15mph test max was 78 i measured 78... i failed the CO test on the 25mph test max was 0.42 i measured 0.62
Old Jun 12, 2011 | 07:16 PM
ex-x-fire's Avatar
ex-x-fire
Make sure your o2 sensor(s) and air pump system is working good, did you get the engine nice 'n hot for the test? You might have to run it hard down the hiway before you test it. If everything is good like compression, vacuum, tune up parts, & clean injectors, you might be looking at a cat converter issue.
To Quick L98 timing question......
