relay on firewall
Old Jun 13, 2011 | 08:25 AM
jaysin's Avatar
jaysin
Default relay on firewall
Does anyone know what the relay is for on the firewall behind the battery on a 1990 coupe 6spd auto climate control?
Old Jun 13, 2011 | 08:55 AM
cgantner5150's Avatar
cgantner5150
MAF relays are behind the battery. There should be 2. I have an 86 but I think they are similar.
Old Jun 13, 2011 | 02:55 PM
Hooked on Vettes's Avatar
Hooked on Vettes
That's the CAGS relay (computer aided gear selection).
1-4 skip shift relay used on the 6 speed manual transmission.
Old Jun 15, 2014 | 03:58 AM
Annoyed's Avatar
Annoyed
NOTE: This thread is from 2011
I would like to know the (correct) answer to this question too.
I'm currently in the process of eliminating some wiring around the battery. I just removed the original fan relay and now bumped into this.. and want it out of there.
It has 4 cables going to it.
2 go into that epicly stupid junction block by the battery.
1 goes into that main wiring loom on the left hand side of the engine bay which runs forward to the headlights. I believe it's black.
1 red cable goes to a circular-single-pin plug.
Edit: I forgot to mention it's directly under the bonnet-stop-holder thingo.. by the door.
Old Jun 15, 2014 | 04:25 AM
Annoyed's Avatar
Annoyed
I found a pic of it in this old(er) Corvette Forum thread
https://www.corvetteforum.com/c4-tec...questions.html
POST #15
That's the one.
One guy says on page 2 "MAF burn-off relay" but I'm not sure which pic/post he's referring to.
I'm going to assume it's the MAF burn-off relay and remove it.
Old Jun 15, 2014 | 07:08 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I suspect that is true.
My '88 has the two MAF relays in that location but your '90 is SD so no MAF relays.
Maybe someone with a '90 or '91 will pop in.
Old Jun 15, 2014 | 07:33 AM
WVZR-1's Avatar
WVZR-1
CAGS relay with VIN 8 is indeed in that location for '90 & '91.
To relay on firewall
