Code 28
Old Apr 23, 2002 | 10:45 AM
Oly's Avatar
Oly
Default Code 28
According to the 1992 Corvette service manual, a code 28 involves "Quad-Driver Module (QDM) #3 5.7L (VIN P) "Y" Carline (Port)". This controls the fan switches and A/C clutch control relay. I have a manual switch to turn the fans on and off; the only time I use it is if I am running around in town in stop and go traffic. Could this be the reason the ECM is recording a code 28? When the switch is set in the normal operating position (off), the fans will operate at the correct temperatures.
Thanks.
1992 LT1
Old Apr 24, 2002 | 05:23 PM
vettes's Avatar
vettes
Default Re: Code 28 (Oly)
TTT
Old Apr 24, 2002 | 05:24 PM
98nassau's Avatar
98nassau
Default Re: Code 28 (vettes)
what does ttt mean?
Old Apr 24, 2002 | 07:29 PM
quiksilver458's Avatar
quiksilver458
dont sure about the code 28.. never heard that one before... an TTT mean to the top.. users type this into a new post to cycle the question to the top.. otherwise it finds its way to 3 or 4 pages into the forum.. :jester
Old Oct 30, 2013 | 12:32 PM
orenkrief's Avatar
orenkrief
i have the same 92 and same fan switch same 28 code .did your vette dies when hot or wont start just after it cold
Old Oct 30, 2013 | 05:50 PM
vetteoz's Avatar
vetteoz
The code 28 involves the #3 circuit which involves the A/C clutch relay and the 2 cooling fan relays
http://forums.corvetteforum.com/1554702604-post3.html
Others have had the code with man fan operation
http://forums.corvetteforum.com/1554768822-post17.html
so I suspect manually operating the fans upsets the ECM because the fans are running without the ECM telling them to so it throws the code
For a code 26 but same principle
http://forums.corvetteforum.com/c4-t...river-4-a.html
Old Oct 30, 2013 | 05:51 PM
vetteoz's Avatar
vetteoz
What other codes do you have current?
Old Oct 31, 2013 | 12:39 AM
Cliff Harris's Avatar
Cliff Harris
Usually a quad driver fault is caused by one of the circuits it drives drawing too much current.
A quad driver turns on 4 different circuits, usually relays or solenoids. The way to approach this is to first determine which 4 things are controlled by that quad driver and then disconnect them one by one, reset the ECM, and then check to see if the error code returns.
Old Oct 31, 2013 | 12:48 AM
vetteoz's Avatar
vetteoz
He knows what is causing the code , the manual switch he is using to bypass ECM control of the fans.
As per the link , the code goes away when the ECM has control of the fans
To Code 28
