I am having the TPI engine from my '87 conv. freshened up. Everything will be stock except for the camshaft. How far can I go without screwing with the computer or injectors? Thanks.
Chuck
When I got my 85 it was stock with the exception of the cam. The previous owner installed a Competition Cam 260 grind (212/218) and roller rockers. It had the original chip. Anything larger will likely reduce your low end power with no upper end gain. I ended up running that cam with a Super Ram intake, AFR heads and TPiS headers. It made good power with lots of low end torque.
From: One day you're a Comet...the next day you're dust... Arkansas
Something with specs like the TPiS ZZ9 will boost performance with TPI.
Since you have it apart why not drop in a cam. Even with a MAF car you should get a tune.
How perfect on tune do you want to be? BADDUK is correct but your TPI system will accept some substantial mods without a tune being essential. Yes there will be ponies on the table but not as many as you might think.
I agree with the previous comments.....a cam is not the best choice for engine modifications with the TPI system intake...the intake is done at 4500 RPM anyway.....
Change the valve springs out and put in a ZZ9 or 211 camshaft, then have someone like PCMforless or Ed Wright do your chip. You can do other things later to improve from there.
Chips are really needed when you start messing with the cam. Other intake and exhaust mods don't necessarily require it but the cam will want a custom tune.
This seems to be in the ballpark of what I am looking for: a nice sounding cam, a slight boost in power for not a lot of money. I am the type of guy who has never put anything back together in stock condition. I am kind of new to Corvettes and not really up on all the equipment. Who carries the ZZ4 or ZZ9 cams? Thanks again.
Chuck
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
