96 LT1 tuning
Old Jun 14, 2011 | 07:46 AM
craneman61!'s Avatar
craneman61!
Default 96 LT1 tuning
I have a hypertech to tune with. I have seen on this forum a recommendation to leave the 180 thermostat in but change the on -off temp on the fans. If you tell the hypertech you have a 180 thermostat did that change the cooling fans on-off from stock settings? If you have a 180 thermostat and say you have a 160 what will happen? Does anyone know the results of these two situations? What about the positives and negatives of each one?
Trying to get the info from the experts. THANKS GUYS!!
Old Jun 14, 2011 | 02:11 PM
STL94LT1's Avatar
STL94LT1
Yes, the 180* setting will change the fans on/off temps, and if you run a 180* stat with the 160* settings the fans will probably continuously run at low speeds or idle once the car is up to temp. If you keep the 180* stat, use the 180* setting.
