1994 corvette will not start, part 2
Old Jun 15, 2011 | 02:02 PM
oliver's Avatar
oliver
Default 1994 corvette will not start, part 2
Thanks everbody for the help so far, here is where I am . Code H 16 no spark, new coil, icm tested good all fuses tested good. I have power going to the opti terminal C. I put a volt meter on terminal A to check for low resolution signal and I get 5 volts when meter is on DC and I get 10 volts when meter is on AC. This reading is there anytime the key is on. Also the reading is the same when cranking. I was told that this reading should be there only when the engine is cranking? Is this bad or am I on the wrong terminal?
Thanks Mike
Old Jun 15, 2011 | 04:35 PM
pcolt94's Avatar
pcolt94
Thanks Mike
It is pin B of the ICM connector that should read 1-4 volts A/C when the engine is cranking. That is the drive from the PCM.
I’m out of town but I know that is correct.
Two other terminals (A & D) have 12 volts DC on them and the other (C) is ground. (from memory).
Old Jun 15, 2011 | 05:59 PM
oliver's Avatar
oliver
My icm plug reads this A 11.52volts, B no volts while cranking, C is a good ground and D 11.52 volts. I seen that a H 16 code could only be caused by an open, shorted, or grounded low resolution wire comming from the opti or a bad optial sensor diode or a bad pcm is there any way to pin point it down? Is this information correct I seen it on u tube for gm training?
Thanks Mike
Old Jun 15, 2011 | 06:05 PM
STL94LT1's Avatar
STL94LT1
Replace the opti and it will start.
Old Jun 15, 2011 | 09:17 PM
pcolt94's Avatar
pcolt94
With the code 16 and especially not having A/C drive voltgage at pin B.
Just to double check, I would put a noid light on an injector. If it does not light when cranking, that would point again to the opti as being defective.
Old Jun 15, 2011 | 10:12 PM
oliver's Avatar
oliver
I put a noid light on and got nothing, I was just hoping in was something else than the opti. What the chance it is the pcm? I just didnt want to do the opti if it wasnt the problem. Thanks everone.
Mike
Old Jun 16, 2011 | 10:16 AM
pcolt94's Avatar
pcolt94
The opti provides the initial timing and clocking pulses (drive) to operate the PCM. No opti operation, no injector drive or ICM drive. To test these individual parts require complex set ups. Of course the PCM could give a similar symptom. So for the average guy fixing his (or her) car, replacement or best educated guess sometimes is the only way to further the diagnosis.
The PCMs are good units unlike the ECMs. Optis are a much higher failure item than a PCM and the odds are in you favor.
Of course is easier to change the PCM just to try it if you had one on your back pocket.
To 1994 corvette will not start, part 2
