headlight dimmer switch replacement 93
Old Jun 16, 2011 | 12:27 PM
tek317's Avatar
tek317
8th Gear
Default headlight dimmer switch replacement 93
The dimmer switch on my 1993 coupe is stuck in the high beam mode. Any help on how to fix or replace it would be greatly appreciated.
Old Jun 16, 2011 | 02:53 PM
THE 383 admiral's Avatar
THE 383 admiral
you will need to disco the battery, for the air bag, you need a wheel puller, plate compressor... after this for a newbie... it will be time consuming and tedious... you will need to route the wires... through the column channel... the high beam rod will not be fun again your first time... I would get a pic from the web or manual.. I can scan one in tomorrow... im sure someone will get you one quicker
Old Aug 14, 2013 | 10:07 PM
Eric Criss's Avatar
Eric Criss
4th Gear
any tips here? im havng a heck of a time getting to the dimmer switch in my 1993
Old Aug 14, 2013 | 10:18 PM
csthews's Avatar
csthews
If the 93 is like the 95, the actual dimmer switch isn't in the steering column, it is behind the panel below the steering wheel. There is a long rod that runs down the column from the lever to the switch. If you are lucky, the rod came unseated from the switch. If you are not so lucky, a certain plastic part (the switch rod actuator) either broke or fell out of the steering column. Once again, that is if the 93 is like the 95. Here is a link to an issue I had with the actuator:
http://forums.corvetteforum.com/c4-t...-actuator.html
To headlight dimmer switch replacement 93
