94 LT1 code 44
Old Jun 17, 2011 | 05:30 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Default 94 LT1 code 44
I know its left O2 sensor reading lean. the O2 sensors are new as of 3 years ago. the check engine light will only come on after I drive it for about 15-20 miles while its hot out. after the light comes on I can smell exhaust and unburnt fuel. the person I got the scanner tool from said I have a vacuum leak on the left side. I checked everything and did not see anything out of the norm
Old Jun 17, 2011 | 06:27 PM
John A. Marker's Avatar
John A. Marker
Check your wires to this O2 sensor. If there is oil...it will contaminate the readings giving a false code 44 and since the sensor is reading actual as something else, it will change your fuel mixture. The oil works it way past the weatherpak connector and onto the wires which changes the resistance being registered by the sensor. Solution...clean the wires and replace the sensor.
Old Jun 17, 2011 | 06:49 PM
Nowhere Man
Thanks will take a look and report back
Old Jun 17, 2011 | 07:40 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
What brand of o2 sensors did you put in when you replaced them?
Several folks report problems with Bosch 02 sensors
Old Jun 17, 2011 | 10:15 PM
Nowhere Man
I used Bosh
Old Jun 19, 2011 | 02:42 PM
Nowhere Man
thanks I looked at everything and it was coated with oil. so i took some break clean and cleaned both connectors then used a electrical cleaner then used dielectric grease. so hopefully that helped
To 94 LT1 code 44
