How many $ for clutch replacement?
Old Apr 23, 2002 | 07:44 PM
clyde's Avatar
clyde
Default How many $ for clutch replacement?
Talked to a shop today after everyones diagnosis of my problem and they said to change the rear main seal and the clutch would be between 600-700$. Does that sound about right? Also any tips on a reliable clutch and anything else I should have done while it's apart?
Old Apr 23, 2002 | 11:31 PM
bogus's Avatar
bogus
Default Re: How many $ for clutch replacement? (clyde)
after much hell... use GM factory...
if that 600-700 includes the parts, a good deal.
Old Apr 23, 2002 | 11:56 PM
quiksilver458's Avatar
quiksilver458
Thats an awesome deal if its parts and labor.. Center force II clutches run for about 400ish from 84 to 88, an 620ish 89 to 93.. Thats a dual stage clutch.. Personally, i have driven vettes with factory replacements, centerforce single plate and dual plate clutches.. Im no professional driver or anything, but friends of mind have had better luck with the single plate for mildly mod'ed engines.. If the car is stock, or near stock.. I personally wouldnt spend the extra money for a dual plate since i've seen two last only six months tops.. (The guys were crummy drivers tho ) Hope this helps..
Old Apr 24, 2002 | 12:02 AM
scorp508's Avatar
scorp508
My centerforce Dual Friction cost $309.95 from Summit, and $32 for the throwout bearing.
Old Apr 25, 2002 | 03:48 PM
Captain_Kaboom's Avatar
Captain_Kaboom
Heh. I spent $1400 at a chevy dealer that does a lot of corvete work and had them completely redo my clutch. I just wanted it done right for once, and they did a fantastic job....
Old Apr 25, 2002 | 08:24 PM
tarheelracer's Avatar
tarheelracer
Default Re: How many $ for clutch replacement? (Captain_Kaboom)
I'm getting mine replaced as we speak along with a new slave cylinder for 1200, so you caught a deal
To How many $ for clutch replacement?
