Can headlight motors install backwards?
Old Jun 20, 2011 | 02:27 PM
cadmaniac's Avatar
cadmaniac
Default Can headlight motors install backwards?
I have another thread on this but i am curious. Is it possible to remove headlight motors (with the brackets attached) and put them back in in reverse?
I painted my car and now the headlights won't open, just close.
Everything looks perfect! It's driving me nuts, and looking at them I dont see how they could be backwards.
Old Jun 20, 2011 | 02:39 PM
oldalaskaman's Avatar
oldalaskaman
cant be done
Old Jun 20, 2011 | 02:49 PM
THE 383 admiral's Avatar
THE 383 admiral
the motors are the same Left & right... there is no way you can put the left light assembly on the right... or vice versa...
Old Jun 20, 2011 | 03:21 PM
engle1147's Avatar
engle1147
Your headlight module may be toast.
Old Jun 20, 2011 | 04:53 PM
THE 383 admiral
can you rotate the headlight up by hand... the common problem is there are 3 nylon bushings inside that disintegrate... and will not rotate the headlight... I would check the electronics first..
you can bypass the leads with a direct 12 volts source... to open and close the headlight...
Old Jun 20, 2011 | 06:02 PM
383vett's Avatar
383vett
Are your connectors ok? DC motors run in reverse in the polarity is switched.
To Can headlight motors install backwards?
