Tall Valve Covers for LT1, is Canton the only Option?
It appears that the factory valve covers are not going to clear my 1.7Scorpion RRs. I have the top end of the motor reassembled, adjusted the rockers and then rested the valve covers atop the heads (gasket is attached to VC). They did not seat. Seems like it is hitting one or more of the poly locks or rocker body. The drip tabs had already been removed from when I had 1.6RR.
I don't particularly want to start grinding away at the valve covers and likely end up ruining them so I am looking into an aftermarket tall set. It seems that the Corvette LT1 valve covers are engineered to clear the alternator and many of the aftermarket covers are specified as non Y-body compliant for that reason. Canton seems to make a compatible set, and really good looking too. Is this the only 'tall' set that will clear the alternator? Any other sets?
I can't swear these will work, but they do clear my Crane Gold 1.6 roller set and they are notched to clear the alternator, they are pricey.
http://www.parts123.com/parts123/yb....5Z5Z50000050F#
If you choose them you will need to use the older style valve cover gaskets used through 92, the thin style used on the LT1 composite covers will not work.
I really like cantons, have one of their road race oil pans, excellent quality, good fit, and I could afford it, thankyou Dr. Huxtable. if I had the money , i'd buy canton valve covers.
