help - power door locks dont work
Old Apr 23, 2002 | 11:31 PM
tim87's Avatar
tim87
Default help - power door locks dont work
I recently bought a 1987 Vette and I notice that neither of the power door locks work. When I press on the switch, they kind of make a clicking noise but won't open or close. On one of them if I push 5 or so times it eventually closes. Both close manually fine. What are the chances that I can get them working if I take the door cover off and try to adjust them? Is there any way to fix them myself without taking them to the dealer and paying big $$$?
Old Apr 23, 2002 | 11:34 PM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Default Re: help - power door locks dont work (tim87)
First, check the three large screws that hold the lock plate to the door - inside the door, where the hatch release and the UAW sticker are.
My locks quit working for a while, and it was because the screws had loosened up.
Next?
Old Apr 23, 2002 | 11:51 PM
quiksilver458's Avatar
quiksilver458
Check those screws.. If that is not it, try removing the door panel.. I have found with experience, (4 c4s) that sometime the lil pin gets wedge in the door frame on either wires or a lil metal circle thing. Its very hard to explain.. Im assuming the problem is one of these two things since you said if u hit the button several times it eventually unlocks.. :) hope it helps..
Old Apr 24, 2002 | 12:02 PM
sputnick's Avatar
sputnick
Default Re: help - power door locks dont work (quiksilver458)
I have the same problem on my 93. Havent yet pulled it apart. Let us know how it goes.
Old Apr 24, 2002 | 04:50 PM
VQT88Vette's Avatar
VQT88Vette
One of the door lock switchs is faulty. The power window switchs are the same as the door lock switchs. You can tell bu looking at the switchs in your car, and is was confirm by many. $5 each from one of those Mid America/Erker(sp) thing. I would buy all four since they won't sell anything less than $20 :rolleyes:. This is correct for 1988, I would assume 87 is the same. Don't know about 1990.
Old Apr 25, 2002 | 03:30 AM
R Cook 92's Avatar
R Cook 92
Default Re: help - power door locks dont work (VQT88Vette)
same problem on my 92, I tore down the entire door, and then put it back together and checked clearence all along the way, turns out the plastic piece that you manually push to lock the door, (that connects to the rod) was getting stuck on the foam behind the door pannel, so I cut back the foam and it worked fine... BUT, if I remember correctly an 87 didn't have the foam rattle insulation behind the pannel, so the moral of my post is: just check those little things out, I suggest pulling them off then seeing if they work.
Any questions on pulling apart the door, just ask, I'm now an expert on the locks... Good luck
Old Apr 25, 2002 | 09:18 PM
tim87's Avatar
tim87
Thanks for all the replies. I plan to check it out this weekend - will leave a post with what I find.
Tim
Old Apr 27, 2002 | 10:59 PM
tim87's Avatar
tim87
I got the drivers side working by putting in a new switch and lubing up the linkage. The drivers side now works from either the drivers side or the passengers side but the passengers side wont do anything - not even click. I havent taken off the passengers door panel so dont know what I'll find there but it obviously cant be the switch since it works the drivers side. Does anyone have any ideas??
Old Apr 27, 2002 | 11:41 PM
quiksilver458
so there isnt even a click in the passenger door?! hmmm... well i doubt it is the switch.. i wonder if the motor is burn out on that door?! anyone else care to jump in?!
:confused:
Old Apr 27, 2002 | 11:54 PM
MDC9966's Avatar
MDC9966
If you find out its the motor, let me know. I have a couple of spares.
Old Apr 28, 2002 | 12:24 AM
VQT88Vette's Avatar
VQT88Vette
Try to test the switch with both doors panel off to see which switch is faulty. My driver side switch was the broken one. Exchange the switchs from driver to pass. to make sure both are OK.
To help - power door locks dont work
