Transmission Time?
Old Jun 22, 2011 | 11:56 AM
WPK's Avatar
WPK
Default Transmission Time?
94 Coupe/LT1/Automatic/160K miles/ Original Transmission and Engine.
It's been hot lately - 90 to 100 degrees. On long trips with A/C on, occasionally, and just occasionally, after a stop - I hit the gas, the engine revs a bit, but no real connect to the tranny..... Then, slowly, it starts to engage, and after a bit, it's back to normal. This is the original tranmission, and never been rebuilt or anything. It's been 60K miles and about two years since last transmission service.
Is this a sign that a new transmission is in the works? Or would it just need to be serviced?
If anyone has any insights, it'd be appreciated.
- WPK
Old Jun 22, 2011 | 01:17 PM
aklim's Avatar
aklim
Have you checked the fluid level and condition? After that, drop the pan and see if there is debris there
Old Jun 22, 2011 | 07:10 PM
WPK's Avatar
WPK
Default Transmission Service?
So, it might make sense to get the transmission serviced?
They would drop the pan.
- WPK
Old Jun 22, 2011 | 07:14 PM
C409's Avatar
C409
- WPK
..... What say YOU drop the pan ... THEY might have ulterior motives ...
Old Jun 22, 2011 | 07:36 PM
87 vette 81 big girl's Avatar
Hopefully only the transmission filter rubber mounting grommet is worn out & sucking air in along with the trans fluid.
Worthwhile dropping the trans pan yourself & see what you find in the bottom of the trans pan & check that rubber filter tube mounting grommet.
Old Jun 22, 2011 | 07:59 PM
383vett's Avatar
383vett
That's exactly what happends if the fluid level is low.
Old Jun 23, 2011 | 03:04 PM
WPK's Avatar
WPK
Default Great - thanks guys.
All great insights... and you have given me good direction.
Thanks mucho all.
- WPK
To Transmission Time?
