Need some advice.
Old Jun 24, 2011 | 12:57 PM
Blkd out's Avatar
Blkd out
5th Gear
Default Need some advice.
Looking at buying a c4 here pretty soon and curious how hard it is to get to the 300-350hp range. If so whatis the easiest most reliable way? Anything would help.
Old Jun 24, 2011 | 03:59 PM
jsiddall's Avatar
jsiddall
I assume you mean wheel HP since all >L98s had 300+ HP out of the factory.
Any C4 can be made to produce 300 WHP with a 100-150 shot of nitrous. If you want the fun to last longer than a bottle any supercharger or turbocharger setup should get you into the 400 HP range.
Old Jun 24, 2011 | 08:42 PM
drjimmy's Avatar
drjimmy
None of the L98's were over 275HP. The 86 only had 230.
Old Jun 24, 2011 | 09:51 PM
Blkd out's Avatar
Blkd out
5th Gear
Lol im looking at a 86 and they claim to have 220 on paper. Starting there what would i have to do to get to 350whp? if it will be difficult i might just steer away.
Old Jun 24, 2011 | 10:56 PM
Brand-X's Avatar
Brand-X
Buy a crate motor or do an eldelbrock power package...not too tough to get 350 whp
Old Jun 24, 2011 | 11:06 PM
drjimmy's Avatar
drjimmy
The 86 was either 230 or 235 if you had the aluminum heads. Bear in mind that the L98 was a torque monster and the 700R4 was geared towards that.
You would need around 440 hp at the crank to get 350 to the wheels. A stock C5 has 350 hp at the crank and would probably be cheaper than building up a C4.
That being said, 440 hp is not a tough goal. Buy a crate motor for $4000 at summit.
Put a turbo on it. Lots of fabrication required.
Put a supercharger on it. Deal with belt slip.
Old Jun 25, 2011 | 11:50 AM
Blkd out's Avatar
Blkd out
5th Gear
I'm actually leaning towards a 96 lt4 convertible that a buddy of mine is selling it has 36k miles and mint cond for 9k it kbb for way more but is it that good of a deal?
Old Jun 26, 2011 | 08:04 AM
PAINTER MAN's Avatar
PAINTER MAN
I think that is a heck of a deal.
Old Jun 26, 2011 | 10:50 PM
jsiddall's Avatar
jsiddall
Not sure if you were agreeing with me or disagreeing. By >L98 I meant "greater than" L98, like LT1, LT4, LT5, LS1... etc. None of the L98s had anywhere near 300 FWHP.
An LT4 with a bit of nitrous could easily do 350 WHP, and 9K is a pretty low entry price! If you like what nitrous does you can always add a turbo or supercharger and get way more than 350 WHP.
To Need some advice.
