master cylinder
Old Jun 25, 2011 | 03:56 AM
calvette88's Avatar
calvette88
Default master cylinder
hey guys just curious i just put a 383 in my 88 and because of the low vacume (big cam) my brakes arnt what they were, so instead of getting a vacume canister i was wondering if someone makes a master cylinder without a powerbooster that would work on my vette thank you
Old Jun 25, 2011 | 06:48 AM
oldalaskaman's Avatar
oldalaskaman
I vote , get the can
Old Jun 25, 2011 | 07:50 AM
Muffin's Avatar
Muffin
Make that 2 votes.
Old Jun 25, 2011 | 11:04 AM
HlhnEast's Avatar
HlhnEast
And three. You will be much happier if you do.
Old Jun 25, 2011 | 12:26 PM
VetteMed's Avatar
VetteMed
Another option is the hydroboost setup like what was used on the Turbo Regals and on 3/4 ton and 1 ton trucks.
Old Jun 25, 2011 | 12:55 PM
leesvet's Avatar
leesvet
There is a steel booster available thats bigger. Your brakes are the same, its the level of assit that you get from the booster. Even a low vac should help a bunch. A vac can with a check valve ain;t a big deal.
I've driven mine without a booster for several weeks, and although very tough in the beginning,. you get used to pushing a bit harder. Whats funny is the first few stops with a new booster
Old Jun 28, 2011 | 08:11 AM
calvette88's Avatar
calvette88
do you know who makes that steel booster?
Old Jun 28, 2011 | 08:43 AM
cadmaniac's Avatar
cadmaniac
I have a huge cam in one of my vettes too. 1 pump then zero brakes. Anyone have any experience with something like this. Pricy I know, but never have to worry again!
http://www.autoanything.com/brakes/69A3151A0A0.aspx
The can didn't work that great for me. Got a couple of extra pumps but in traffic it doesnt work well.
Good luck!
Old Jun 28, 2011 | 10:21 AM
yedister's Avatar
yedister
Good luck!
I have one in my 86 becuse at idle I had 10 inch of vac. It work fine but, if I had to do it again, I would go with a Hydrobooster just because I wonder sometimes about the electric motor stop working when I need it.
Old Jun 30, 2011 | 12:17 PM
calvette88's Avatar
calvette88
thats what im thinking thank you to all that answered
To master cylinder
