L98 Water pump replacement question......
Old Apr 24, 2002 | 11:29 AM
Wheelman's Avatar
Wheelman
Default L98 Water pump replacement question......
for those of you who have done this: where did you get a heater hose fitting long enough to clear the ac bracket that mounts to the water pump studs? Everything i find at the autoparts store is too short. My old one wouldnt come out of the old water pump....
thanks
[Modified by C4Fetish, 9:29 AM 4/24/2002]
Old Apr 24, 2002 | 07:21 PM
OnDVirg's Avatar
OnDVirg
Default Re: L98 Water pump replacement question...... (C4Fetish)
I just did this replacement on my 85...don't know if it's totally the same or if the part is what I'm thinking of, but it it's the metal tube out of the water pump, it's threaded and all you do is unthread from the old water pump and apply to the new. Is it something different? :cheers:
Old Apr 24, 2002 | 07:25 PM
Wheelman's Avatar
Wheelman
Default Re: L98 Water pump replacement question...... (OnDVirg)
right that is exactly what im talking about but my old one wont budge from the old water pump.
Old Apr 24, 2002 | 07:26 PM
quiksilver458's Avatar
quiksilver458
parts stores dont have different lenghts?! they do here.. :D
Old Apr 24, 2002 | 07:29 PM
Wheelman's Avatar
Wheelman
Default Re: L98 Water pump replacement question...... (quiksilver458)
heh i forgot im kinda posting after the fact, finally at the 5th autoparts store i went to, i found the one that i needed, just this morning actually.
thanks for your help anyway though :cheers: :cheers:
To L98 Water pump replacement question......
