Shifting too early ?
Old Jun 26, 2011 | 10:32 AM
Calderone's Avatar
Calderone
Default Shifting too early ?
This test was made with the selector on "Drive" position , i have a SuperRam ,58mm TB,AFR195, 3200 Stall, B&M Shift Kit, 3.07 gears
Should i push the TVCable inside a bit , safely, without cooking the trans ? Thanks
Old Jun 26, 2011 | 12:02 PM
383vett's Avatar
383vett
Caleb, you would want to change your wide open shift points by lightening up the governor weights, not changing the tv cable. Since you are pretty close, and your part throttle points I assume are good, take off the cap and remove the governor. You can shave a little of the outside edges of the 2 weights (use a dremel or grinder). Clean, replace and test drive. You should be able to raise your wot points to where you want them to be. Willie
Old Jun 26, 2011 | 12:10 PM
87 vette 81 big girl's Avatar
Sammy,
Adjust the TV cable on your 1987 Vette exactly as the 1987 FSM shows & directs you to.
No other way.
Change shift points like 383 Vette said to.
Changing governor weights & springs or with a Sonnex Blue governor gear assembly.
B&M 700R4 & Turbo 400 Governor recalibration kit is what many recommend here.
Calderone's Avatar
Calderone
I've read about it and i don't want to shave them because it might affect low rpm shift points maybe ...i saw this "Superior Shift point Package" pack, any of you have use this?
http://cgi.ebay.com/ebaymotors/330352037720
Old Jun 26, 2011 | 12:11 PM
Calderone's Avatar
Calderone
Originally Posted by 87 vette 81 big girl
Sammy,
No other way.
Thank you Brian !
This is the one then !
http://www.summitracing.com/parts/BMM-20248/
Old Jun 26, 2011 | 12:13 PM
No, but SUPERIOR makes very good transmission blueprinting parts too.
Have some of their items in my 87 vert 700R4 also.
Old Jun 26, 2011 | 12:15 PM
Calderone's Avatar
Calderone
This is news for me , never did anything to the governor
so this is what i need then
Old Jun 26, 2011 | 12:25 PM
383vett's Avatar
383vett
For the most part, wot is determined by weights, part throttle by springs. The kits have weights that are a lot lighter than stock. You'll have to mess with both springs and weights. It takes a lot of time. Been there, done that. I would still recommend shaving the weights. It'll affect wot much more than part throttle.
Old Jun 26, 2011 | 12:26 PM
Yes.
Its a good idea to check TV cable adjustment as part of your routine maintenance such as during oil changes or setting overhead valves.
Improperly adjusted TV cable & your C4 700R4 will protest badly & die an early death on you.
TV cable & plunger inside of valvebody is the brain that determines light throttle driving & WOT full line pressure for fast full power driving & racing.
Millions of 700R4's have died early on because of improperly adjusted TV cables.
Brian
Old Jun 26, 2011 | 12:30 PM
Calderone's Avatar
Calderone
ouch sounds like a long project !
i didn't want to shave them since some chip might get in or so...
Yes.
Brian
Yes i know , i've seen a couple die !
I'm pretty sure its fine but i will double check it , i believe its fine because i'm always shifting very hard on it , it has taken a lot of abuse
since i overhauled it 3 years ago.
On "2" seems to get higher RPM's
Old Jun 26, 2011 | 12:33 PM
Calderone's Avatar
Calderone
Btw ...i posted another thread about my Tach, seems to work fine ?
bypassed tach filter :
http://forums.corvetteforum.com/c4-t...ash-video.html
Old Jun 26, 2011 | 12:35 PM
Check TV adjustment anyway Sammy.
I recheck mine every time I change oil at 3,000 miles.
I check it not once but 3 times to be sure.
I took a hacksaw blade & scribed a permanent line along the protruding adjustment nose to always know where it was at when I installed my freshly rebuilt 700R4 by me.
If the TV cable is out adjustment badly,
Your 700R4 will die within 50 miles driving fast.
Likely 1 or 2 1/4-mile full power passes.
You drive fast like me too I know.
Better safe than sorry I say.
Recheck TV anyway.
You will sleep better at night that way.
BR
Old Jun 26, 2011 | 12:37 PM
Calderone's Avatar
Calderone
will check then !
Hey Brian, how my tach does look like ?
i cannot remember the way they work
thanks
Old Jun 26, 2011 | 12:59 PM
holding my son nicholas right now sammy.
i will write/ post later to you on c4 on your unaswered thread.
have 1st hand experience with tachometer read out problems on my 87 vert too.
its in the lcd - liquid crystel display itself.
seen a static discharge high kv voltage spike shorting out internal wiring invisible to your eye.
removed, present under lighting with a magnifying glass & sharp eyes.
have to go be a father for now.
later sammy,
brian
Old Jun 26, 2011 | 01:01 PM
Calderone's Avatar
Calderone
No worries, say hi to Nick !!!!!
enjoy it , you won't notice when he will be drivin your 87 !!!!!
time flies extremely fast !
To Shifting too early ?
