ABS pump runs when at stoplight.. '86E Auto
Old Jun 28, 2011 | 11:30 PM
ConnecticutJunkman's Avatar
ConnecticutJunkman
Default ABS pump runs when at stoplight.. '86E Auto
This started happening a few days ago and has been getting worse..
When at a stoplight with my foot on the brake the ABS pump just starts to run moving the brake pedal up and down.
I have no loss of braking and the brakes seem to be working fine when the car is moving. The pump doesn't come on under normal braking.. just when im already stopped at a light or something for a few seconds.
If i inch the car forward or completely take my foot off the brake the pump stops.
Any ideas?
Old Jun 29, 2011 | 07:09 PM
TWISTERUP's Avatar
TWISTERUP
Have you checked for the possibility of water having been in the compartment which holds the ABS---I've seen that cause problems although not what you are describing--just a thought.
Old Jun 29, 2011 | 08:46 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
When you are stopped how hard are you pressing the pedal? The ABS might be sensing a panic stop. Just a thought.
Old Jun 30, 2011 | 12:11 AM
jfb's Avatar
jfb
Your ABS computer is in need of repair.
Old Jun 30, 2011 | 01:06 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Just for a test, try pulling the ABS fuse and see if the brakes are still working normally.
FWIW I cannot understand how GM has left all of the C4 ABS systems out on a limb?!!
Somebody out there has the test equipment. Does anyone know where we can get our ABS modules test/repaired?
Old Jun 30, 2011 | 02:43 AM
cv67's Avatar
cv67
St. Jude Donor '05
Keep googling ABS module rebuilders.
Some are repairable some are throwaways. Seems about 120 is avg to have them done.
Old Jun 30, 2011 | 06:12 PM
JrRifleCoach
Well I finally found the Kent Moore ABS Tester J-35890 for a reasonable price.
First to test it and see what options are available.
Then I might consider renting it out.
Not to hijack this thread....... so I'll start another when the unit arrives
Old Jun 30, 2011 | 08:06 PM
ConnecticutJunkman
Just enuf to keep the car stopped while im sitting at a light.. very light pressure. If i let up and let the car inch forward the pump stops.
Old Jun 30, 2011 | 08:12 PM
ConnecticutJunkman
No i have not! And that is a good thought because it has been raining like crazy here and my weatherstripping isnt all that great. I will check the bottom of the ABS compartment and report back tomorrow.
PS: my ABS light does work and it is not coming on. The system self tests itself when i 1st move. The ABS seems to also to work fine.. I intentionally tryed locking the wheels on wet pavement and it kicked in and didnt throw a light.
Old Jul 3, 2011 | 10:04 PM
HeeHaw89's Avatar
HeeHaw89
Exact symptoms on my 89, inquired here on forum few years ago Was told to check/clean speed sensors at each corner Didnt feel like it so unplugged abs fuse problem went away i've never needed the abs so dont care
(my period key on laptop not working, sorry for run on sentence effect)
To ABS pump runs when at stoplight.. '86E Auto
